SIKTOY wrote:I disagree with the forced induction on beams.
There are many aftermarket kits (most well known is blitz) for SC and turboing the beams engine with pretty good results using factory internals and cams etc.
SIKTOY wrote:Very true mmm boost,
but they are no worse than any other high comp NA motor.
As for bolt on kits, why not a bolt in motor?
3SGTE anyone? A lot easier, cheaper and reliable to get a write off and swap all the go fast bits in and convert to FR configuration.
Or am I tired and missing some vital piece of info that will prevent someone from doing this?
SIKTOY wrote:If you want lots of info, surf through HERE
You'll learn EVERYTHING you ever needed to know about altezza's.
SIKTOY wrote:damn, they are supposed to be in columns, i forgot about that, hope you can understand.
Beams = bloody good valve timing system (basically)
Note: Toyota quotes the RS beams engines at 147KW. (197 HP)
Mr Revhead wrote:when at rally hawkes bay there was a car yard with 2 altezzas on the yard with big front mounts....
just in case anyones keen for a look.
its not a cheap job... just the other day i priced a blitz s/c kit for one.
if your lucky you can get it on the car and running for under $9k
SIKTOY wrote:Everyone finished ripping me to pieces?
I remove myself from this conversation before anyone feels the need to shoot me down some more.
farewell ladies and gents.
