HAHAH this is what i did...
Lasted a whole 10 mins... nuty|mike will vouch for me when i say it was a $$% awesome ride
the engine can handle the PSI as long as you be very careful in the setup..
I had a AW11 MR2 and had a flange welded on the bottom to fit a T3 from a skyline.
Parts i had were intercooler, extra injector controller, and a few other bits but me being too impatient, i hooked the turbo up, and fed that straight into the intage manifold. ran it in diagnostics mode as it voids the PSI readings over +3PSI (or what ever it is).
Took it up the road a few times and something went pop, and smoke was everywhere.
If i had have taken my time, and spent a little more on getting things fitted properly then it would have been sweet.
Stock fueling, timing and no IC is not a good look
Would be a good idea to go aftermarket ECu as has been said but if you wanna do it on the cheap, make sure its on the sensible side
