Neon installation
Postby Sick Puppy » Sat Sep 10, 2005 10:22 pm
[looks around, knowing he's gonna get razzed bigtime! :) ]
Okay guys, ball park figure- how much for a set of neons plus installation? :oops:
Aarrrgghh! Can't believe I'm doing this! Must- not- press- submit key...
Oops, too late :P
Why not, they'll look good on my curren... now for the clear indicators... :)
Sick Puppy
Postby Vertigo » Mon Sep 12, 2005 12:14 pm
well, mine cost $125 from Iceobar Imports, however, installation is up to you :p
actually, its really not that hard ive found... now ive got the front and rear ones in... but being a AE80, the sides are going to be hard, without some sort of side skirts. can anyone help me out in that department?
Vertigo
Postby Vertigo » Mon Sep 12, 2005 12:15 pm
actually, the wiring could be daunting if you arent used to wiring your own circuits, but even then its not that bad.
getting the nerve up to actually drill into the body of the car is probably the worst thing!
Vertigo
Postby Vertigo » Wed Sep 28, 2005 8:34 pm
hmmm... this is going to be harder than i thought.
i cant find anywhere to mount the side neons.. to those that have done this before, themselves or by a shop, what were they mounted onto? pics would be ideal too plzplz.
(boohoo story, skip if you like)
i really would like to get this done soon.. before i even started with these ones, i had bought some little 12cm tubes for laughs, and since then have grown to like them, hence the upgrade. but the small tubes can be seen from the outside.. if i cant get the new tubes installed soon, ill have to remove the old ones and have no side neons :( cry.
Vertigo
Postby Ae92typeX » Wed Sep 28, 2005 10:13 pm
One of my mates and several others ive seen were mounted just on the other side of the sill seam (where the wheel jack goes). my mates one also had alloy shielding facing outwards so the lights could not be seen when on, just a glow on the ground.
Ae92typeX
Postby Vertigo » Thu Sep 29, 2005 11:28 am
ah great - thats exactly what i was pondering doing. thanks.
Vertigo
Postby barryogen » Fri Nov 04, 2005 12:17 pm
AJz wrote:well for a start front and rear are illegal
if you are having neons on your car, just like with any other non factory lights, make sure they are legal.
give this a read.....under cosmetic lighting...
http://www.ltsa.govt.nz/vehicle-safety/get-your-lights-right.html
Had a look, don't see how they would be illegal.
ltsa.govt.nz wrote:Fitting requirements
Cosmetic lamps can be any colour as long as they meet the following requirements.
* They must be angled downwards and fitted so that the light source isn’t directly visible from the front or back of the vehicle (this will prevent the lights distracting, confusing or dazzling other road users). See diagram below.
* You must not be able to see the light source (lamp) from anywhere in the shaded zone.
* They should only give off light that is spread out (diffuse) rather than light concentrated in a beam.
* They must not be positioned close to essential lights such as headlights or indicators.
* They must not flash, pulse, fade in and out or change colour.
* They must not revolve, rotate or move in any direction.
All that is easy to comply with, just dont make the "lamp" visible from the front/back
barryogen
2ZZ Guru in training
Postby Vertigo » Sun Nov 06, 2005 6:46 pm
thats correct, but also from the sides.
in the end, i got some 170cm aluminum strips and bolted them well to the sill. neons attached to the middle of those (on the inside side of the skirts :P)
if you ever see a green corolla with electrical tape racing stripes and badly spraypainted flat (albiet crumbled a little) skirts, that would be me.
Vertigo
Postby alastabesta » Sun Nov 06, 2005 7:46 pm
rage wrote:okay so reading that ltsa site. u can have neons of any color and around all sides of the car AS LONG AS you cant see the actual neon tube ?
if you take your car to onroad you might either get craps thrown at you, or a pass with :roll: depending on which inspector you get...
from what I understand it, they must be off while the vehicle is operating(aka moving). having said that I have yet to receive a ticket from the police.
but be warned you WILL get pulled over alot and the police will ACTIVELY be looking for things they can write you tickets for (rego, wof, any other things like tyres wider than the fender...etc)
i mounted mine inside the side skirts for the side, behind the front bumper and underneath fuel tank at the back if that's of any help to ya :P
2001 Caldina GT-T
alastabesta
