drftnmaz wrote:when getting spacer make sure there not multifit or you wont get your cert. they have to only fit the car as if they were designed just for it.
bad20v wrote:Adjust your rear camber out and/or get spacers for them.
Fraud wrote:drftnmaz wrote:when getting spacer make sure there not multifit or you wont get your cert. they have to only fit the car as if they were designed just for it.
Even if they are not multi-fit they will not pass a cert unless the wheel is centered on the hub. The wheels are not only allowed to be on the studs, even if the studs are longer. (must be 'hub-centric' or some cr@p)
drftnmaz wrote:Fraud wrote:drftnmaz wrote:when getting spacer make sure there not multifit or you wont get your cert. they have to only fit the car as if they were designed just for it.
yea this thought had crossed my mind but then i thought about all my mags and none of them fit the hub in the center...
but if were talking about 3mm it should still sit on the center of the hub??????
Fortyone.co.nz wrote:Don't grind the coilovers!
Trueno20v got these off us - fortyone.co.nz - and we both knew prior to purchasing these that there may be a hurdle or two as these are for AE100's not his specific make =]
trueno_20v wrote:Fortyone.co.nz wrote:Don't grind the coilovers!
longer studs and 8mm spacers should be done tomorrow so will put all back tomorrow night didnt have to touch coilovers
