Turbo choice and av gas?
Postby Liloss » Mon Sep 12, 2005 1:46 pm
Righ first q...
What would be the best option for a single turbo set-up on a 3 litre? Wont be running any huge amount of boost just the stock levels. It's not a toyota engine but any turbo will do as i need to make a new maniold anyway...
Secondly, What damage would be cased by running AV gas in a 3sge? Since 96 is still $1.57 and AV gas is only $1.10 it might be a good option if the 3sge will run it without destroying it, But i do understnas it can burn the valves out?
~~Liloss~~
Liloss
Postby Dell'Orto » Mon Sep 12, 2005 1:48 pm
Depends on your goals really...T66's seem to produce decent power, as well as not being toooooo laggy ;)
Avgas will (over time) kill your o2 sensor. Potentially your wallet too if you get caught running it 8O
Postby Adamal » Mon Sep 12, 2005 2:14 pm
Yup, Avgas is illegal and the cops will kick your ass if they see you're using it (Leaves a visable light greyish colouring on your exhaust)
Postby rolla_fxgt » Mon Sep 12, 2005 3:07 pm
Yeah if ur gona run avgas, best to put a dump pipe on the end of the exhaust so the cops cant see the residue on it.
though does a 50/50 mix of avgas & 91 limit tbe o2 sensor damage & stop the residue?
rolla_fxgt
Postby Dell'Orto » Mon Sep 12, 2005 5:13 pm
I think it would lessen the coating of the o2 sensor to an extent, but it doesnt stop the residue.
Postby Santa'sBoostinSleigh » Mon Sep 12, 2005 5:18 pm
plus avgas smells very distinctly - the avgas topic has been bashed to bits lately - check out the SEARCH button :P
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby bad20v » Mon Sep 12, 2005 5:32 pm
Santa'sBoostinSleigh wrote:plus avgas smells very distinctly - the avgas topic has been bashed to bits lately - check out the SEARCH button :P
Yeah coz normal petrol is getting too expensive so ppl are tryn to find alternatives. As for me, I'm experimenting with making my own special blend of 'go-juice' in the lab at work. Almost there, just got to get the octane rating up a bit and work out the price per litre. :D
Thank-You.
bad20v
