Removing Half Shafts.
Postby Silent Knight » Sun Sep 18, 2005 2:34 pm
Right well I'm stuck at the moment as I don't have a puller. I've removed my diff housing etc from the Soarer and now need to get the diff head out but the half shafts won't budge...
Anyone have any ideas?
Silent Knight
Postby TrouserFxGt » Sun Sep 18, 2005 3:58 pm
Are there any threaded holes in the flanges?
If there are then you could use a bolt through them to jack the 'half shafts' out. Check to make shure there is nothing else holding them in first.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Ae92typeX » Sun Sep 18, 2005 6:29 pm
unless there somehow different, Ive always used a crowbar or similar to pop them out.
Ae92typeX
Postby Cody » Sun Sep 18, 2005 6:30 pm
If they are anything like the supra's (should be the same) then all you should do it impact them out....the are held in by a ring clip like cv joints normaly.
just remember when you go to refit them you may have to replace the locking ring.
Cody
Postby edwagon » Sun Sep 18, 2005 10:09 pm
gas axe 8)
edwagon
Postby Silent Knight » Sun Sep 18, 2005 10:13 pm
Yea I've gone out and bought two crowbars and I've actually managed to bend the one the crowbar today and they still don't move... :?
Only thing left to do really now is take it to Diffs R Us. If they can just pull the shafts out wich will take all of 3 minutes with a proper puller then it'll be easy to change things over and put it all back in.
Silent Knight
Postby edwagon » Mon Sep 19, 2005 11:06 am
they must be really stubborn! my only other suggestion would be a slide hammer but if you don't have one then thats not much good! you could try hanging the whole unit about 6 inches from the floor by chaining the halfshaft flange to a beam and dropping the unit so it pulls the halfshaft out of the centre, but you're probably better off just paying $20 and not wrecking something by being rough.
edwagon
Postby Ae92typeX » Mon Sep 19, 2005 11:57 am
Silent Knight wrote:Yea I've gone out and bought two crowbars and I've actually managed to bend the one the crowbar today and they still don't move... :? ...
edwagon wrote:"edwagon"]they must be really stubborn!...
they must be!, the bar trick has not failed me yet. Guess, like you say, its time to take to diffs r us...what a bastard.
Ae92typeX
Postby Silent Knight » Mon Sep 19, 2005 1:02 pm
Yea it is a complete pain in the ass really. All this hasle for something so trivial...
I've though about a chain and dropping it but I don't have a chain and the shitty garage roof would probably cave in from the weight of that if I tried... :P
AFAIK there's no circlips or anything else holding them as I can't see anything. Called Mark at Diffs this morning and he is busy all day so will take it in to him tomorrow morning first thing to get the shafts taken out. Hopefully putting them back in is not going to be as big a pain in the arse as taking them out...
Silent Knight
Postby Cody » Mon Sep 19, 2005 5:58 pm
The clips are actualy on the spline towards the end and locate the thing in as well as hold them, then again if you have beed doing burnouts etc there could be a problem with twisting on the spline......be interested to find out why they havnt come out as they should have.
best post pics of what they look like when you have them pulled so we can all see what was what.
Cody
Postby Silent Knight » Mon Sep 19, 2005 6:03 pm
The Soarer hasn't really had that sort of a thrashing though. I've only ever done 1 real burnout with at Meremere months ago.
Will see tonight as Mark has been kind enough to have a look at it for me tonight. He obviously has more diff experience to me and this is the first one I've ever tried pulling apart.
Thanks will post pics if anything interesting pops out.
Silent Knight
Postby Rob » Mon Sep 19, 2005 6:12 pm
With toyota ahafts you need two bars 180 degrees apart and lever evenly.
Should come out piece of piss
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Silent Knight » Mon Sep 19, 2005 6:13 pm
Rob wrote:With toyota ahafts you need two bars 180 degrees apart and lever evenly.
Or so everyone says....we've had 2 people with crowbars on both sides trying to pry them loose. All to no avail...
Will see what happens tonight, if it all fails then I'll be seeing Mike at Diffs 730 tomorrow morning. :wink:
Silent Knight
Postby Silent Knight » Tue Sep 20, 2005 1:20 am
Yes we finally managed to pry it off with the help of edwagon who has now officially become my HERO!!!
All goes to plan she should be running by tonight again. :D
Silent Knight
Postby sigma » Tue Sep 20, 2005 5:05 pm
i remembered having to do this on the sigma, was easy, jacked it up, took of wheel, took off drum housing and partially bolted it on backwards and used it as a makeshift slide hammer, ahhh the good old days, who needs disc brakes?
1985 MR2 AW11 20v
sigma
Postby edwagon » Tue Sep 20, 2005 10:57 pm
Haha cheers dude.
Let me know how it drives!
And thank god the mighty soarer shares nothing in common with a filthy old sigma!! :lol:
edwagon
Postby Silent Knight » Wed Sep 21, 2005 12:21 am
haha yea true.
Jason was kind enough to let me use his workshop tonight to put the diff etc back together. What a bloody mission. Took about 45mins worth of bashing to get the half shafts back in there... 8O
At least she's all ready to go now. After work tomorrow will be putting her back in and taking the bitch for a gud ol' thrashing!!! :D
Silent Knight
Postby Silent Knight » Thu Sep 22, 2005 8:32 am
Right well she's in and going again except for a wee little exhaust leak wich will be fixed once I get some sealant for the gasket...
Haven't thrashed her in the dry yet but this morning at around 630am when I pulled out of the driveway for work and roads were still a little damp I gave it just a small amount of gas and she crossed up so nice and easy!!! :D
I'm lurVVVViNg it :wink:
Silent Knight
