ST185 GTFour Rear Axle/Suspension Bushes
Postby BR0Z » Fri Sep 23, 2005 9:31 pm
Hi All
I'm looking for replacement bushes for the Rear hub/axle carrier for my GT Four RC :( . Can the bushes themselves be bought or are they part of the axle carrier assembly?
Is there a Nolethane kit for these bushes< :?
Can anyone offer suggestions & possible costs.
Cheers, Mark
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
BR0Z
Postby Malcolm » Fri Sep 23, 2005 10:38 pm
I imagine it's probably a spherical bearing type thing (kinda similar to a tie rod internally). Some places can rebuild them, but some people have been known to replace them with plain urethane or similar bushes, as there isn't much axial movement required, AFAIK
Postby GT4 20 » Sat Sep 24, 2005 12:28 am
Try Fensport in the UK. IIRC, rear bushes are pretty much the same as the ST205 - just replaced all mine with ones from Fensport.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Rob » Sat Sep 24, 2005 10:33 am
I went to SAS and asked for something similar in nolathane as you can't get the right ones. They cost from memory about $60
To remove the old ones I suggest a vice and a 5lb bashometer
Nolathane has far less play
Also check your wheel bearing as it could end up cheaper to buy a complete hub from toyota if you need to pay for the services of a workshop press
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby BR0Z » Sat Sep 24, 2005 11:04 am
Thanks Rob :D , Who/where are SAS - have you got their contact details.
Cheers, Mark
Oldie but goodie
Mark Bros
BR0Z
Postby Malcolm » Sat Sep 24, 2005 1:46 pm
Rob wrote:I went to SAS and asked for something similar in nolathane as you can't get the right ones. They cost from memory about $60
complete hub + carrier + wheel bearing from Toyota would be big $$. A hub on it's own (just the flange with the wheel studs in it and the part the inner bearing race goes over) will be over $100 retail, wheel bearings are about $150 retail from memory, and the carrier (which is the part you need) would probably more than the two combined.
also the reason there's more "play" in the stock bush is because it's meant to be able to swivel about it's axis.
Postby aesc » Sat Sep 24, 2005 4:13 pm
SAS - Suspension Autoparts Specialists
They are opposite Repco in Sydenham, in the same complex as Stocks
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Rob » Sat Sep 24, 2005 7:07 pm
A complete hub from toyota if I remember is 500 bucks + GST ex japan
Rob
Postby BR0Z » Tue Sep 27, 2005 1:15 pm
Thanks ppl :D
Have ordered kit from Stocks which is $141.25+GST for SuperPro polyurethane bushes (8bushes +4Tubes) same as Fensport SuperFlex.
SuperPro are the Australian manufacturer who sell to Fensport.
But Fensport chg 60GBP for a kit per side, then there's shipping on top.
Then the fun will begin to put them in.
Cheers, Mark
Oldie but goodie
Mark Bros
BR0Z
Postby Rob » Wed Sep 28, 2005 1:28 pm
My bushes were only about $60 for 4
Rob
Users browsing this forum: Google [Bot] and 34 guests
