king springs vs tanabe springs
Postby oem-r » Fri Sep 23, 2005 2:16 pm
hey guys am looking for a set of aftermarket lowering springs.
on trade me you can get brand new king spring lows or super lows for $350 and tanabe lowering springs for $275 which lower car 40mm all round.
wondering if anyone has had expirence with the springs and how they ride etc... too saggy stiff?
chers :)
oem-r
Postby bad20v » Fri Sep 23, 2005 2:20 pm
lol, I think you can get King Springs from Stocks for cheaper than that!!! :lol:
Use the 'Search' function, this topic has been covered several times.
P.S: I would go TRD, although Tanabe isn't a bad spring either. :wink:
Thank-You.
bad20v
Postby Boldy » Fri Sep 23, 2005 3:38 pm
[plug]
hey I got some Vogtland springs for my pug 205 gti, they are sweet. Lowered the car by about 35mm, it handles even better, but still a fairly comfortable ride (for a 205 anyways!!!). The guy who sold them too me is on toyspeed, and runs a company called suspension progress ltd. He does a bunch of stuff for toyotas I think. I won't post his email, but PM me and I can give you his addy (hope you don't mind keith!!!)
[/plug]
Boldy
Postby Torz » Fri Sep 23, 2005 3:41 pm
king springs suck (even though I have them installed in my car atm).
Edit: Forgot to mention, I have a spare set of King Springs (front & rear) for SW20 if someone wants to buy it. Although I must mention that my front-right spring is a little compressed and woulnt recommend it.
MR2 GT Turbo... Sold
Torz
Postby Mr Revhead » Fri Sep 23, 2005 4:06 pm
id rather have stock springs over kings
Postby Torz » Fri Sep 23, 2005 4:56 pm
Heh stock springs. The only problem I had with mine were the nose lift under high boost (used to always scare me). Thats the only reason I installed King Springs.
Torz
Postby oem-r » Fri Sep 23, 2005 9:46 pm
bad20v wrote:lol, I think you can get King Springs from Stocks for cheaper than that!!! :lol:
how much can u get king sprngs thru Stocks for??
oem-r
Postby beeker » Fri Sep 23, 2005 10:12 pm
How good are Stocks ? Someone recommened me to them. I need a Targa Rally front setup on my AE86, and TRD have killed off their lower spring rate product (250lb).
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby bad20v » Mon Sep 26, 2005 1:55 pm
Depends on the type and age of the vehicle and the availability at the time.
Thank-You.
bad20v
Postby bad20v » Mon Sep 26, 2005 2:03 pm
beeker wrote:How good are Stocks ? Someone recommened me to them. I need a Targa Rally front setup on my AE86, and TRD have killed off their lower spring rate product (250lb).
Stocks are fairly good at building custom setups for any vehicle. But in saying that, they charge through the nose for that type of work!
I have got them to build me a couple of coilover setups using Koni Adjustable inserts, but a couple of times they didn't follow my build design and changed a few bits so it was easier and cheaper for them to build, which in turn made the components not work properly. :?
So if you want something custom made through them, specify exactly want you want, get a quote for the job (and make them stick to that price, not a cent more!! Otherwise they will over charge you!!) and get a time for completion( otherwise it will be a week or two late!!). :D
Thank-You.
bad20v
