Gear box to fit 5k in ke25
Postby darkest_one_666 » Sun Sep 25, 2005 11:53 am
hey i was just wondering what gearbox would fit up to my 5k in my ke25 as my one sounds like it has shit its self which is a pain in the ass. ive heard starlet gearbox's fit up into it sweet, im not sure what is in mine currently as it was put in there before i got it and the center consol piece that come down between the 2 front seats had to be pulled out as the gearbox came forward to much, it is a 5spd. hoping to get another 5 spd for it so i was just wondering what gearboxes from certain cars i can use.
.:: If Nismo means Nissan motorsport.. then wouldnt Homo mean Honda motorsport ::.
darkest_one_666
Postby ke_25 » Sun Sep 25, 2005 11:56 am
you can use the k50 from both starlet (kp61 etc) and ke70...
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby darkest_one_666 » Sun Sep 25, 2005 12:58 pm
will the support mounts fit and bolt str8 on and everything?
darkest_one_666
Postby ke_25 » Sun Sep 25, 2005 6:26 pm
it will fit straight up, although im pritty sure if useing the starlet box you need to use the x memebr for that and you need to drill new holes for it to mount up as they are slightly different, and mayb increase the hole for teh shifter in your gearbox tunnel slightly, if it hasnt already been done so for the box in there now... i think..
ke_25
Postby darkest_one_666 » Sun Sep 25, 2005 6:31 pm
yeh i hav, with the gearbox thats in it now the shitfer just about hits the handbrake! and we had to take the dash between the seats out becos of that problem
darkest_one_666
Postby wde_bdy » Sun Sep 25, 2005 8:46 pm
Starlet is same layout as KE2* and KE3*, KE70 box is different with shifter further back.
Callum
wde_bdy
Postby darkest_one_666 » Sun Sep 25, 2005 8:50 pm
thts the answer i was looking for, cheers man! nice an simple haha
darkest_one_666
Postby AE85coupe » Mon Sep 26, 2005 10:51 am
you can also find a t50 bellhousing from a 5k corona (t40) and use a t50 if you really wanted to
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Virtual Genocide » Mon Sep 26, 2005 7:30 pm
Problem with that is you then need to use the hydraulic clutch or convert to cable.
Appaerntly there are some T50's with cable that bolt sraight into KP's, very rare tho.
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby KE20 » Tue Sep 27, 2005 7:22 pm
jusy a bit of useless info,if you ever upgrade the engine to say a 3sgte or 4agte a w55 front shifter will fit in the factory ke20 tunnel.
KE20
Postby suberimakuri » Mon Oct 03, 2005 3:53 pm
Virtual: TA22 T50 is the rare one. I used 2tgeu in my ke35 with standard dshaft and ta22 t50 bolted straight in on factory mounts.
suberimakuri
Postby Virtual Genocide » Mon Oct 03, 2005 6:25 pm
...and it is cable clutch?
Virtual Genocide
Postby suberimakuri » Mon Oct 03, 2005 6:34 pm
yeap
suberimakuri
Postby wde_bdy » Mon Oct 03, 2005 9:06 pm
If its cable clutch its not a factory TA22 bellhousing, the T series cable clutch setup is pretty rare.
Callum
wde_bdy
Postby suberimakuri » Tue Oct 04, 2005 9:38 am
oh?... must be an ex japan TE27/37 box then that i had...
suberimakuri
Postby wde_bdy » Tue Oct 04, 2005 5:21 pm
Karl_Skewes wrote:oh?... must be an ex japan TE27/37 box then that i had...
Nope, they were hydraulic as well, I think they were a van box or something. Very hard to find though.
Callum
wde_bdy
