Help! where to plumb up boost guage on 4k turbo!
Postby crnkin » Tue Sep 27, 2005 10:23 am
Hey guys,
Im thinkin out of the emmisions control pressure hole ibn the manifold, but the fuel is already mixed there, or should i just plumb it up to my custom airbox????
thanks!
(its completely stock carb and box sealed- setup btw)
deaf_homo "currrently yes"
crnkin
Postby CozmoNz » Tue Sep 27, 2005 11:38 am
Well, plumbing it off the airbox will just give you a vac reading, and not a terriably accuriate one.
you need to find somewhere, where vac exists (when not on boost), when Boost exists (when on boost haha), and that dosnt have fuel mixed with it.
I dont know jack about carbie turbos, but thats what ya need haha, the carbie must have some vac hoses on it though X_X.
Randly try some :D, its only vac hose.
Rayne For President!
CozmoNz
Postby crnkin » Tue Sep 27, 2005 11:55 am
hehe ok :) cheers
crnkin
Postby CozmoNz » Tue Sep 27, 2005 12:06 pm
dont you need a blow through carb though? vac carbs go a bit anal when you blow air up their arses dont they?
CozmoNz
Postby crnkin » Tue Sep 27, 2005 12:20 pm
hehe we will see tonite but supposedly theyre mint to 15psi
crnkin
Postby Dell'Orto » Tue Sep 27, 2005 1:55 pm
Cozmo, if you dont know, STFU, k?
crnkin, tap a feed into the inlet mani, and run it from there, would be the best bet.
Postby SIDE_FX » Tue Sep 27, 2005 2:12 pm
wat about jus after the turb in the inty plumbing???? i know i know i havent heard of it being done before but the pressure should be const throught the who system(its written in my physics book)
SIDE_FX
Postby CozmoNz » Tue Sep 27, 2005 4:31 pm
Mmm, Boost wrote:Cozmo, if you dont know, STFU, k?
so your telling me its fine to have a air fuel mixture running to the boost gauge?
minter, just dont smoke in the cabin, yaknow, just incase ;).
CozmoNz
Postby Lloyd » Tue Sep 27, 2005 6:37 pm
If you want a proper reading then you'll need somewhere after the throttle. As suggested, get a feed from the inlet manifold or just get a T-piece and go into a hole thats under vacuum when the engine is running
Postby drftnmaz » Tue Sep 27, 2005 9:30 pm
i'd put it into your box over your carb but you wont see vac much only boost really.
on my 4k turbo i have the boost gauge running fuel thro it and havet had and issues YET (only drivin it a handfull of times) its got issues
how are you regulating the fuel pressure? and are you retarding the dissy at all?
drftnmaz
Postby crnkin » Tue Sep 27, 2005 9:48 pm
just got back from the lock up.
Currently has no exhaust and no oring to seal the turbo but it IS boosting a little, will finish the dump pipe and oil leaks on thurs
Yeah im gonna plumb it into the inlet manifold, im just running stock fuel for now, may take the jets out on thurs, and retard the dizzy to whatever works :)
seems to go alright tho and has a MEAN whistle!
crnkin
Postby drftnmaz » Wed Sep 28, 2005 4:40 pm
yea i jst finished my exchast (except for the pipe off the wastegate :twisted: ) i'm running suck-tho and it blows flames out of the wastegate so i can't leave it exiting in the eng bay... :roll:
yea mine whistles hard out sounds sooo weird...
the best bit about it is the increase in torque. the first time i drove it it was pissing down with rain and i had it sideways down my whole street :roll:
what fuel reg u using :?:
drftnmaz
Postby crnkin » Wed Sep 28, 2005 4:47 pm
none, just stock fuel pump for now, will see how it goes tho!
i just wanna sell the thing
crnkin
Postby pervert » Wed Sep 28, 2005 4:51 pm
Sedan or wagon? How much are you looking at getting...???
pervert
Postby crnkin » Wed Sep 28, 2005 4:54 pm
wagon, 4 door, semi slant, (86) with wheels etc, 2500 ono
crnkin
Postby pervert » Wed Sep 28, 2005 4:55 pm
Dammit...I don't want a wagon... :cry:
pervert
Postby crnkin » Wed Sep 28, 2005 4:56 pm
ahhhhhhhhhhh everyone loves wagons :) nah sweet as, you could swap the bits over, but i needed a wagon for my DH bikes and stuff, like carting 4ages to and from aucks :)
crnkin
Postby drftnmaz » Thu Sep 29, 2005 3:48 pm
if you run blow through you have to have a rising rate fuel reg.
standard fuel pressure= ~5psi, boost= ~7psi, its just gonna push the fuel back thought the pump.
drftnmaz
Postby crnkin » Thu Sep 29, 2005 7:38 pm
hmmmmmmmmm what pressure reg shgould i run? and how to mount it on a mechanical pump line? :S
crnkin
Postby drftnmaz » Fri Sep 30, 2005 3:53 pm
mayb look for one off a cordia turbo or 12a turbo or a malpassi made for carbie turbos?? i don't think you could aucally use a mech pump cause they never really go past 6psi or so... so i'd use a ele one from the car u get the reg off?
you'd mount it after the pump b4 the carb and plumb the return back into the inlet of the pump or run a return line to the tank
drftnmaz
