AE101 front swaybar bushes
Postby AceSniper » Thu Sep 29, 2005 5:02 pm
hey, im just wondering if anyone knows of a shop that will do them, as nolathane dont seam todo them an i was told only toyota and TRD would do them with the shape of the back of them. Anyone know of a place that will do them custom with out costing a ton and know what there doing?
AceSniper
Postby bad20v » Thu Sep 29, 2005 6:03 pm
Super strut or non? :D
Thank-You.
bad20v
Postby AceSniper » Thu Sep 29, 2005 6:12 pm
Non :p
AceSniper
Postby Mr Revhead » Thu Sep 29, 2005 7:06 pm
dude, cheap and easy.... email :wink:
Postby bad20v » Fri Sep 30, 2005 11:18 am
Mr Revhead wrote:dude, cheap and easy.... email :wink:
Yeah, email Warwick or find a suspension shop that sells the 'SuperPro' brand of bushes. They are the equivalent of Nolathane, and some people reakon they are better and last longer. Its just a replacement urathane bush but people like brand names. :roll: :lol:
When you ask them for the bushes, they might say that they don't have them for non-super-strut AE101. Ask them for AE92 bushes instead, as they are pretty much the same suspension wise and the bushes should fit. :D They are about $20 for a set (Retail).
Thank-You.
bad20v
Postby aesc » Fri Sep 30, 2005 11:30 am
AFAIK front suspension bushes are just round shaped, they are not like the rears where they have a flat edge to them. I had the same type of problem when I replaced mine a while back, as I thought the fronts may have had a flat edge to them too but they dont.
I ended up buying some genuine bushes off Warwick, but if you go into SAS they will sell you some universal Superpro or Nolathanes. I know the front sway bar on S/S is 24mm, dont see why non should be diff
EX AE101 owner
2013 Ford Focus ST
aesc
Postby AceSniper » Fri Sep 30, 2005 11:53 am
thanks for the help :)
yea its that angled back on them that seams to be the problem, any idea of part numbers that fit? (superpro)
Iv emailed revhead so Ill prolly just replace with stock items :)
AceSniper
Postby AceSniper » Fri Sep 30, 2005 12:00 pm
while ontopic :D
Also the front Arm bush's I have atleast one thats cracked an turned to shit, has anyone replaced them? how easy is it... or do they have to be press fitted an all, also anyone got part numbers for them?
AceSniper
Postby Mr Revhead » Fri Sep 30, 2005 12:01 pm
which one? the front or rear on that arm?
Postby AceSniper » Fri Sep 30, 2005 1:57 pm
prolly both sides i know its a front one that looks completley screwed but the rest arnt much better, were the A arm fits onto the X Member
AceSniper
Postby Mr Revhead » Fri Sep 30, 2005 2:03 pm
from toyota thats part of the A arm.....
Postby bad20v » Fri Sep 30, 2005 2:03 pm
Front Lower Control Arm Inner Front Bush: Part # SPF0996K (SuperPro)
Front Sway Bar 'D' Bushes: Part # SPF0991-24K (SuperPro)
:D
Thank-You.
bad20v
Postby AceSniper » Sat Oct 01, 2005 1:47 pm
sweet checked it out today
The front swaybar is SPF99124k
Just checking b4 I order since im lazy its 24mm is the swaybar on a 93 AE101 non superstrut with ABS have a 24mm bar :lol:
Also looks cheaper to just replace the front arms at $50ish+ per bush
AceSniper
