846mc installation
846mc installation
Postby 86_rolla » Thu Sep 29, 2005 8:49 pm
i just brought a clarion 846mc and was trying to figure hout how to install it caz the wire diagram is too confusing. ive got a sony one in there and i was like yip i just follow the wires but the clarion has like twice as many. so, i need to no what colour wires are for what.
black (earth??), thin yellow, orange w/ white stripe, blue w/ white stripe, blue, red, brown, green w/ black stripe, green, white w/ black stripe, white, grey, grey w/ black stripe, purple, purple w/ black stripe and a thick yellow one.
haha any help would b great, if anybody can suggest a cheap place to install it that wld b awesome also.
86_rolla
Postby Monster_Magnet » Fri Sep 30, 2005 11:32 am
Black= Earth
Red= Power (ignition)
Thick Yellow=Constant power From battery
Green=Speaker +
G\Black=Speaker -
Purple=Speaker +
P\Black=Speaker -
White=Speaker +
W\Black=Speaker -
Grey=Speaker =
G\Black=Speaker -
(cant Remeber what ones are left and right front and back)
Blue\White = Amplifier Remote
(Unkown)
Orange\White
Thin Yellow
Brown - Possibly dimmer wire for lights.
Monster_Magnet
Postby DeeCee » Fri Sep 30, 2005 12:22 pm
heres the install manual:
http://www.prodigit.net/ClarionDB/manua ... 6MC-AS.pdf
2.9mb
it tells you the eact wire code.. and small yellow is the changer power wire, but as you won't be using it unless you have a changer, cover the end with heat shrink or electircal tape and zip securely to the loom :)
GT Four Adovansu
DeeCee
Postby 86_rolla » Fri Sep 30, 2005 2:04 pm
cheers guys thanks for the help
86_rolla
HELP....again
Postby 86_rolla » Fri Sep 30, 2005 4:43 pm
this is prolly a really noob question but ah well. I hooked it up today (power and earth, sub and amp) and nothing happend no screen no nothing. Now do u have to have the power for the igntion for it to work or is that just so it turns on and off when igniton turns on and off? :oops:
86_rolla
Postby DeeCee » Fri Sep 30, 2005 4:45 pm
depending on the car, you wire the red lead off the back of the headunit to your ignition wire.. in my celica its a thin grey wire :)
GT Four Adovansu
DeeCee
Postby 86_rolla » Fri Sep 30, 2005 4:55 pm
what i mean is shouldnt it still turn on even tho i havent got the igniton leade hooked up?
86_rolla
Postby DeeCee » Fri Sep 30, 2005 5:04 pm
no - unless you wired the red ignition turn on directly to the power wire :)
GT Four Adovansu
DeeCee
Postby Monster_Magnet » Fri Sep 30, 2005 5:10 pm
No it won't I did the exact same thing the first stereo I brought.
I don't know how to explane it but if you dont have power going into both the red and the yellow it will not work.
Simple test twist the ends of yello and red together then twist the ignition wire to the red/yellow and it should start right up not a problem.
Try not to use the factory earth just mount it to the chassis instead as the earth on my nissan was tied into the headlights so when they went on it dimmed the stereo display at night.
So when i turned the cd player on with the head lights It would pop the fuse weird i know but thats what happend.
Serves me right for buying a NISSAN
Monster_Magnet
Postby 86_rolla » Fri Sep 30, 2005 5:11 pm
cheers deecee and monster magnet, ure a ledgends, i thought i had f**ked it.
86_rolla
Postby Alex B » Fri Sep 30, 2005 5:24 pm
Monster_Magnet wrote:No it won't I did the exact same thing the first stereo I brought.
that would be because you earthed the HU on to one of the dash light wires. Not the fault of the car at all. Nissan = good.
And yes thats a good test, but dont leave it like that otherwise it will loose its memory every time you start the car, or wont switch off when the cars switched off, depending on if you used the battery wire or the acc wire :D
Postby Monster_Magnet » Fri Sep 30, 2005 5:31 pm
Sorry about the nissan remark but I just find so many of there factory extras to be a pain in the butt.
Like seat belt pre tensioners had to replace them pain in the butt and the earthing thing and alot of mechanical parts.
I really didn't like that car.
Monster_Magnet
Postby Alex B » Fri Sep 30, 2005 6:00 pm
nah your right on that account, their electronics can be a bit of a bastard using weird relays etc. But all in all i dont think their that bad :)
Postby 86_rolla » Sat Oct 01, 2005 12:34 pm
just finisheed getting it installed and it sounds mighty fine (well.. to my untrained ears anyway). :D :D
86_rolla
