l1ttle_d3vil wrote:just had a brief read over that thread...is it possible thats partly whats wrong with my engine? I don't have the tvis wired up, but still have the butterflies bolted in.
its still not running consistently, after I replaced the temperature sensor on the back its running ALOT better and much quicker but not all the time. other times its either really crap right through the range or its not until it gets to 4500rpm that it takes off.
any thoughts please? im pretty pi$$ed off as after I replaced the temp. sensor it seemed to fix it and run consistently, but not any more...
ee904age wrote:The ECU triggers a vacuum solenoid that opnes them at the set RPM.
