what is TVIS
what is TVIS
Postby auch » Sat Oct 01, 2005 7:29 pm
hey guyz what is TVIS and what does it actually do? it seems people take them off...
auch
Postby Jebus » Sat Oct 01, 2005 7:44 pm
Its a series of electric superchargers in your inlet manifold, thats why 4AGE's are so fast.
A quick search may help.
Jebus
Postby auch » Sat Oct 01, 2005 7:53 pm
so technically a 4agze are twin charged, electrically and mechanically...
so why dont old single throttle 4age adapt this system into their intake system?
what exactly are these TVIS located? if they were to be faulty, would it fully restrict the intake path?
auch
Postby Caveman » Sat Oct 01, 2005 8:02 pm
Caveman
Postby Alex B » Sat Oct 01, 2005 8:02 pm
:lol: :lol: :lol:
He was joking, do a search.
Postby Jebus » Sat Oct 01, 2005 8:02 pm
No im sorry dude, im taking the piss cos you didnt search :P
Anyways theres a plate between the motor and the inlet manifold, which has 4 butterflys on it, below 4350rpm they are closed so the motor only has half the intake port size (to give it better low down torque) then above that rmp they open giving you full power.
This lets them get good drivability and low down torque with relatively big ports
Jebus
Postby RedMist » Sat Oct 01, 2005 8:03 pm
Bugger Jebus, that could have gone so so far!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Jebus » Sat Oct 01, 2005 8:04 pm
Reckon I could get away with it and make some $$$ on trade me :lol:
Jebus
Postby Malcolm » Sat Oct 01, 2005 11:49 pm
ah I was looking for that thread, why hasn't it been FAQ'ed?
Postby Dell'Orto » Sun Oct 02, 2005 12:42 am
Good point, have done so.
Postby l1ttle_d3vil » Sun Oct 02, 2005 12:48 am
just had a brief read over that thread...is it possible thats partly whats wrong with my engine? I don't have the tvis wired up, but still have the butterflies bolted in.
its still not running consistently, after I replaced the temperature sensor on the back its running ALOT better and much quicker but not all the time. other times its either really crap right through the range or its not until it gets to 4500rpm that it takes off.
any thoughts please? im pretty pi$$ed off as after I replaced the temp. sensor it seemed to fix it and run consistently, but not any more... :twisted:
Postby crnkin » Sun Oct 02, 2005 1:46 pm
l1ttle_d3vil wrote:just had a brief read over that thread...is it possible thats partly whats wrong with my engine? I don't have the tvis wired up, but still have the butterflies bolted in.
hmmm
if you have no tvis wired up but the butterlys are still in the spacer plate, theres a good reason why your car isnt revving out, its a/f ratio is super super low, and i presume also that its flapping around causing inconsistancies, as 4500 is where tvis really shines, and other times they will be closed, having no top end power.
Maybe you need to look at wiring it up or taking the butterflys out
deaf_homo "currrently yes"
crnkin
Postby auch » Sun Oct 02, 2005 2:11 pm
a sweet... so the TVIS pretty much works the same as giving variable intake volume same aim as the v-tecs. plenty of low end torque and lots of support during the top end.
so do you guys think this wasnt developed any further?
auch
Postby auch » Sun Oct 02, 2005 2:29 pm
hey thanks for the link, it was a good read. i might missed reading it but i'll ask anyway... how are TVIS activated? thru crank or cam sensor? is it a flap valve similar to a throttle butterfly or a fan like blade that produces head positive pressure as it is pneumatically coupled?
by the way, what does TVIS stand for?
auch
Postby crnkin » Sun Oct 02, 2005 3:33 pm
i forget the actual thing of what it stands for but i always thought it was toyotas variable length induction system. Its controlled by air pressure sorta like a turbo wastegate.
ee904age wrote:The ECU triggers a vacuum solenoid that opnes them at the set RPM.
:D
um its a butterfly, pivots in the middle... annnnnnnnnnnd its nothing like vtec, but same aim- yes, that of low end torque high end power and minimum trade off between around town and boosting it. They probly didnt develop it much cos of the vvti system thats successful on blacktops
crnkin
Postby ee904age » Sun Oct 02, 2005 3:34 pm
Toyota Variable Induction System.
They are butterlies, just like in a throttle body. The ECU triggers a vacuum solenoid that opnes them at the set RPM.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby auch » Sun Oct 02, 2005 5:30 pm
ok so its vacuum operated thru opening of a negative pressure via electric solenoid...
wow thats pretty good how toyota innovation came up with this method but why do you guys think all manufacturers nowadays have taken the route of variable cam timing instead? i mean aside from the secondary/TVIS butterfly valves creating flow restriction and the fact that the mechanism is alot heavier which promotes more weight and bulkier intake system...
good stuff guys keep it coming ;)
auch
Postby Alex B » Sun Oct 02, 2005 5:37 pm
Because its just that, more variable especially with VVT-i
Postby Dell'Orto » Sun Oct 02, 2005 7:47 pm
Interesting, I wonder if my TVIS is actually wired up...does anyone have a link to a page on how to test it?
Postby RedMist » Sun Oct 02, 2005 8:33 pm
Actually manufacturers are using variable length intake systems. Mitsu, BMW just to name a couple. Just nothing as basic as TVIS. The Variable intake timing or lift doesnt negate the need for a variable length intake system.
F1 cars still run Variable length runners.
RedMist
