by Stealer Of Souls » Mon Oct 17, 2005 3:25 pm
What are you gonna use the car for? And how harsh a ride can you handle?
AE85 with bluetop 4age, T series rear, ae86 brake setup all round.
-King springs (std lower approx -30mm) - A little softer than most aftermarket springs, but provide a ride that is quite survivable for daily madness. Also allows some rapid speed bump traversing with loosing all the fillings in your mouth, or getting airborne...
-KYB shocks - A little harder than a lot of common shock replacements. Makes for fast steering response.
-24mm front sway bar, 18mm rear swaybar. (Factory AE86 are 22 & 14)
-Urethane bushes all around except for a couple that were too expensive for me.
-1/2 cage
All in all, a very streetable combination.
If I had the money I would go for adjustable shocks with some good non-adjustable springs (about 30-40mm lower), bigger bars (24 & 16 would be good), strut braces (front and rear), 15 inch rims (195/50-15 ??) and urethane bushes (on at least all the important areas, talk to experts on this).
