6 Speed Supra Box Vs. The Good Old W55
Postby eightytrueno » Sat Oct 08, 2005 2:19 pm
KE20 wrote:i got a w55 and 236kw @wheelandive done 28,000km on it,most of thatis giving it hell as well. the only thing that keeps anoying me, is the plastic bush in the gear stick falls out, other than that its mint.
^^^ i have the exact same problem with my w55, dam plastic bush.
man unless you have a big budget and are not goin to leave a single stone unturned on your car, its hardly worth rebuilding a w55 for $1200. i wish i could say i see your logic in rebuilding it because it drives better, but in my opinion i think the real logical option would be to save $1150 and spend it elsewhere. w55s are good solid boxes, even with higher km's clocked up.
eightytrueno
Postby crnkin » Sat Oct 08, 2005 3:40 pm
AE101_REAR_DRIVE wrote:e.g BZG AE101 Half Cutt = $475 dollars for rear $600 for the front.
whats an ae101 bzg?
deaf_homo "currrently yes"
crnkin
Postby fourplay » Sat Oct 08, 2005 11:06 pm
AE101_REAR_DRIVE wrote:Can get half cuts of most vehicles for around the $500 to $800 dollar mark depending on the vehicle and whats in it.
ST205 Celica front cut ?
If so how much ?
fourplay
Postby DC » Mon Oct 10, 2005 9:30 am
How much for a JZX90 turbo half cut?
Previous Skid Cars (the good ones): 300ZX TT Manual, Bluebird Turbo, RX-7 S1 Bridgeport, RX-4 sedan, R30 Skyline Turbo (x4), Datsun 1200 Coupe Turbo, Low Valiant Ranger XL on 17's
DC
Postby DC » Mon Oct 10, 2005 9:32 am
DC
Postby AE101_REAR_DRIVE » Mon Oct 10, 2005 10:26 am
JZX90 half cut your paying for the engine on that at a premium $1650 for the front cut and then shipping on top thats automatic not manual and if you want the engine and ecu it's even cheaper as your not getting half a car with it.
And as for the ST205 if you want a half cut of a 3SGE i can think of later models with gen 3 3sgte for around the same price as above.
Turbos start at atleast 1000 for late models and for sr20det rb20dets etc are 300 starting as all there doing is taking up space they dont use these motors anymore as most arn't emissions compliant an to old now.
Thank God Im Not Silent_Knight Other Wise I Would Have To Kill Myself
AE101_REAR_DRIVE
Postby MrOizo » Mon Oct 10, 2005 10:30 am
how about a JZA80 turbo manual front cut?
MrOizo
Toyspeed Legend
Postby fourplay » Mon Oct 10, 2005 2:04 pm
AE101_REAR_DRIVE wrote:And as for the ST205 if you want a half cut of a 3SGE i can think of later models with gen 3 3sgte for around the same price as above.
What do you mean by that exactly? I don't want a 3SGE that's why I asked for an ST205 = GT4 = 3SGTE.
It's specifically the ST205 Celica front cut that I want :!:
Please PM me with contact details if you are serious.
fourplay
Postby fourplay » Sun Oct 16, 2005 10:06 pm
fourplay wrote:.... if you are serious.
Didn't think so :lol:
fourplay
Postby crnkin » Sun Oct 16, 2005 11:22 pm
me now have wrote:
knowitall wrote:ae101 bzg
crnkin
Postby matt dunn » Mon Oct 17, 2005 11:02 pm
That is the only problem we ever found with the W55 we all use,
apart from the odd shift fork failure caused by a rough driver.
We have brass bushes made up for the w55 boxes and get rid of the feeling that you refer to as the '20 year old gearbox feel'.
Makes them feel like new again.
Sure they may have worn syncro's but when it's a race car and all it ever get is hard rough high rpm changes the syncro's dont last anyway and they are not needed as they still shift fine when worn with a slight snick on the down change. We did rebuild one and there was no advantage over the worn ones we were using.
The only failures we had with them were HP related.
We have run the W55's in the last few projects we built and have had more trouble with the one car we built with an R154 than all the W55's,
and we have also been lead to believe that the 6 speed supra box is not all it's cracked up to be.
Matt
Users browsing this forum: Google [Bot] and 24 guests
