Did AE85/6 come with engine underbody tray ?
Postby beeker » Sat Oct 08, 2005 4:39 pm
I'm looking at making one up to keep the air pushing through the radiator but obviously don't want to recreate the wheel if there is a factory one.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby NA Drifter » Sat Oct 08, 2005 6:10 pm
u mean the bit that under the fan?.. between the radiator andengine at the bottom?... if so, then yes, they come out with these from factory.. they are plastic
Keith
NA Drifter
Postby beeker » Sat Oct 08, 2005 6:21 pm
NA Drifter wrote:u mean the bit that under the fan?.. between the radiator andengine at the bottom?... if so, then yes, they come out with these from factory.. they are plastic
Does it go from the bumper lip to underneath the radiator, and help force air through the radiator ?
06 RS4 Avant
beeker
Postby NA Drifter » Sat Oct 08, 2005 6:31 pm
oh that bits.... well, they actually do come with those, but most of the one i saw, they have not got it... missing? I don't have it in mine too,... no biggie
Keith
NA Drifter
Postby beeker » Sat Oct 08, 2005 6:50 pm
NA Drifter wrote:oh that bits.... well, they actually do come with those, but most of the one i saw, they have not got it... missing? I don't have it in mine too,... no biggie
Its a bigge for me, as i want to intentionally tunnel as much air as possible via the FMIC and Radiator. Else it just pushes down out the bottom hole (between bumper and radiator) and you loose allot of cooling effect. If there is a tidy OEM solution, it'll save me fabricating something.
I might see the local toymotor dealer on monday and look at their parts diagrams.
thx
06 RS4 Avant
beeker
Postby Stealer Of Souls » Sat Oct 08, 2005 9:32 pm
I've never seen an 85/86 with one. If they do exist, it wouldn't surprise me if they all go missing pretty quick.
I just mocked one up from that plastic board they use for real estate signs...
You should consider a full complete ducting system from the from bar. The undertray alone isn't all that effective, still too much unguided area for the air to escape through...
I haven't made all my ducting yet... waiting for copy of my bumper to come back before I start. :D
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Sun Oct 09, 2005 9:21 am
Stealer Of Souls wrote:I've never seen an 85/86 with one. If they do exist, it wouldn't surprise me if they all go missing pretty quick.
thx
I had planned to make up an Alu one, but once I started to template it with cardboard it started looking a bit hard (not impossible). My other alternative was to use rally car underbody protection (thick and slightly flexible plastic, and I think?? heat resistant). This way I could ensure it sealed well, didn't vibrate, and easily made. Not sure on where to buy it though.
06 RS4 Avant
beeker
Postby Stealer Of Souls » Sun Oct 09, 2005 10:41 am
I've seen it done from ABS plastic before. Not sure where you would get it from though.
But it looked like a good choice. Easy as pie to cut with a hack saw, and can be bent into shape by heating it with a heat gun...
How comprehesive are you making it?
The one I've mocked up is just basically flat. The front edge sits inside the little lip of the bumper and then goes back and under the undertray that is behind the radiator. Wasn't too hard to mock up.
I'm gonna try and source some ABS for the final one. And it'll probably be bolted to the lower lip of the bumper and then head along the same lines as my mock up...
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Sun Oct 09, 2005 12:50 pm
Stealer Of Souls wrote:I've seen it done from ABS plastic before. Not sure where you would get it from though.
yip something like you said. The soul aim is to push more air through the radiator and FMIC and make them work. I have a seperate thick Alu sump guard to protect that.
06 RS4 Avant
beeker
Postby Stealer Of Souls » Mon Oct 10, 2005 9:36 am
Hey.
What's your email? I'll send you a copy of the articles I saw where they made an undertray from ABS. It might give you some ideas as to how you can do yours.
'86 AE85.5 Levin
Stealer Of Souls
Postby dori-kin » Mon Oct 10, 2005 3:03 pm
Hi Beeker
I've got those undertrays (2 pieces) on my 86. I'll take a picture and post it on here when I've got it on the hoist this weekend.
Or you can get a beatrush undertray!
dori-kin
