NA Drifter wrote:u mean the bit that under the fan?.. between the radiator andengine at the bottom?... if so, then yes, they come out with these from factory.. they are plastic
NA Drifter wrote:oh that bits.... well, they actually do come with those, but most of the one i saw, they have not got it... missing? I don't have it in mine too,... no biggie
Stealer Of Souls wrote:I've never seen an 85/86 with one. If they do exist, it wouldn't surprise me if they all go missing pretty quick.
I just mocked one up from that plastic board they use for real estate signs...
You should consider a full complete ducting system from the from bar. The undertray alone isn't all that effective, still too much unguided area for the air to escape through...
I haven't made all my ducting yet... waiting for copy of my bumper to come back before I start.
Stealer Of Souls wrote:I've seen it done from ABS plastic before. Not sure where you would get it from though.
But it looked like a good choice. Easy as pie to cut with a hack saw, and can be bent into shape by heating it with a heat gun...
How comprehesive are you making it?
The one I've mocked up is just basically flat. The front edge sits inside the little lip of the bumper and then goes back and under the undertray that is behind the radiator. Wasn't too hard to mock up.
I'm gonna try and source some ABS for the final one. And it'll probably be bolted to the lower lip of the bumper and then head along the same lines as my mock up...
