exhaust wheel touching housing.
Postby 1598cc » Thu Oct 13, 2005 1:10 pm
i got a td05, but the exhaust wheel is JUST touching the housing.. enough to hear is scraping when turning it.. can i just leave it and let it wear down or what.
cheers.
1598cc
Postby RS13 » Thu Oct 13, 2005 1:22 pm
Err.. if the wheel itself wears down, throws itself out of balance at 80,000rpm.. you'll be picking pieces of wheel out of the muffler, after having the car towed home.
RS13
Postby SLIDE_WAYS » Thu Oct 13, 2005 2:06 pm
Hmmm needs a rebuild me thinks other wise as stated before picking peices out of the exhaust isn't good thing to be doing.
Have heard of skylines loosing exhaust wheels and getting them jammed in the down pipe and causing huge back pressure at the turbo.
S13 Silvia - Stroked CA18DE With 4 Throttles
83 Cosmo - 12AT Running 17 Pound.
MA61 Supra - Manual + HKS Cams and Exhaust
AE101 Levin - Foxtons Kit, Stage 2 Cams
AE86 Levin - Check My Page
SLIDE_WAYS
Postby EVL GSXR » Thu Oct 13, 2005 2:09 pm
Bahahahahaha let it wear itself down do it and see what happen's!!
As everybody else has said you'll be picking bit's out of the back of the car and you'll prob root the turbo housing completely meaning even more money then a rebuild with a machined comp cover and new wheel etc if you were to do it now..
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby 1598cc » Thu Oct 13, 2005 2:21 pm
mite just take the housin off a grind where its touchin. its barely touching so i doubt itd fall to peices
1598cc
Postby EVL GSXR » Thu Oct 13, 2005 2:23 pm
1598cc wrote:mite just take the housin off a grind where its touchin. its barely touching so i doubt itd fall to peices
Yeah but it must have become off balanced so what's saying it's not going to get any worse causeing even more damage??
www.lowndvs.co.nz
EVL GSXR
Postby RomanV » Thu Oct 13, 2005 2:25 pm
RS13 wrote:Err.. if the wheel itself wears down, throws itself out of balance at 80,000rpm.. you'll be picking pieces of wheel out of your face
corrected. :lol:
Postby Malcolm » Thu Oct 13, 2005 2:31 pm
chances are that if it's touching the housing then there is too much play in the bearings, this could lead to a very severe failure due to wobble at high RPMs. Fix it *nod*
The other possibility is that the shaft is slightly bent, which is even worse
Postby 1598cc » Thu Oct 13, 2005 2:36 pm
exhaust housings cracked so id say its shifted slightly over time. ill grind it out anyway and see what happens. turbos are cheap as anyway so doesnt matter if it fuks out.
1598cc
Re: exhaust wheel touching housing.
Postby SLIDE_WAYS » Thu Oct 13, 2005 2:37 pm
1598cc wrote:enough to hear is scraping when turning it..
What makes you think that it hasn't worn down to the point it is now and has maybe only a few more k's left in it anyway.
It won't just wear down the wheel either it will do the housing in as well not a good thing for a poor turbo to experience. 8O
SLIDE_WAYS
Postby RomanV » Thu Oct 13, 2005 2:43 pm
Yes, but isnt there the possibility of:
Your engine oil getting metal in it, and circulating it through the engine?
or
Bits of turbine blade entering the intake/intercooler/engine/etc, if the turbo has a catastrophic failure?
Postby SLIDE_WAYS » Thu Oct 13, 2005 2:46 pm
RomanV is right imagine a large bit of impellar wheel flying in your inlet manifold and into your cylinders then getting it jammed between the piston and block sure it's fine if your wanting to rebuild your engine new block and all.
SLIDE_WAYS
Postby EVL GSXR » Thu Oct 13, 2005 2:46 pm
or
But who care's Turbo's are cheap :lol: :lol: :lol: :lol: :lol:
www.lowndvs.co.nz
EVL GSXR
Postby 1598cc » Thu Oct 13, 2005 6:28 pm
:roll:
exhaust wheel , not compressor .. clown
sorted now anyway , dude before me had taken housing off and not put it back on straight.
1598cc
Postby Loudtoy » Thu Oct 13, 2005 7:20 pm
1598cc wrote::roll:
Imagine it seperated - only slightly enough to jam your impeller side somehow, impeller wheel flys to bits and then you get what he said - doens't matter it's all imaterial now that you've found the fault and fixed it. Turbo's can do funny things tho!
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
