SLIDE_WAYS wrote:like you had man I know where you live and you know where I live
JONES AFTER WORK MY PLACE CAN YOU GUESS WHO THIS IS
Low_Aa63 wrote:ahh but when it comes to f series lsd on the irs if you didnt get one factory... you WONT get one after market!
Low_Aa63 wrote:the only thing similar between f series irs and independant is the crown and pinion wheel size! the spider casing/lsd clutches/whatever you put in there is not the same and will not fit! Irs being the bigger one ofcourse!
