Ignition Wire Colour
Postby GGnz » Thu Oct 13, 2005 4:12 pm
Hey,
Trying to use the Ignition Wire to power up my guages. What is the colour of the Wire for a AE111 Trueno? I only want it so the guages turn on when in the ON possible and not the ACC?
Any help would be appreciated.
Cheers.
GGnz
Postby pervert » Thu Oct 13, 2005 4:14 pm
If you can't find which one the ignition is, just use a multimeter to see which fuses in the in-cabin fuse box have voltage in the right key positions, and get the power from there.
pervert
Postby AceSniper » Thu Oct 13, 2005 4:17 pm
or just prod the main ign wires with a test light
AceSniper
Postby GGnz » Thu Oct 13, 2005 4:18 pm
So are they different colours with different Toyotas? I dont have a multimeter and was hoping someone might know the colour code. Im assuming it would probably work fine on ACC anyways.
GGnz
Postby GGnz » Thu Oct 13, 2005 4:23 pm
Its all right, found it on the net :D.
http://www.the12volt.com/request/2000corolla.asp
Seems to be either Black/Yellow or Black/White/
GGnz
Postby Jebus » Thu Oct 13, 2005 4:26 pm
id get a test light and test just to be sure. most $2 shops have them.
Jebus
Postby pervert » Thu Oct 13, 2005 4:28 pm
Seriously, get a $10 multimeter, you seem to have a lot of electrical related problems, it must be $&#$% hard to do things without one...
pervert
Postby GGnz » Thu Oct 13, 2005 4:36 pm
Just cut the Black/Yellow one and guess what?
Nothing turned on. No dash lights, no A/C. Just the headunit lol.
So it was the Black/Yellow after all. Guages are almost finally done. Thanks for your help :)
GGnz
