Oily problem with blk top 20v
Postby ROBODISCO_20v » Sun Oct 16, 2005 12:38 pm
I have a oily problem with my black top 20 valve in my ae111. Every now and then mainly after i've been driving around town at 50kph i can smell oil burning & ocasionally white smoke will come out the exhaust while i'm idling. I thought it might be oil from the rocker cover breather pipe going into the intake, so i riped it all off but it was as dry as a bone in there. The only other thing i can think of is i've blown my head gasket or something so oil is getting into the cylinder directly from a gallery? I did have a problem with the car running lean at low revs & this may have caused some damage. I have also noticed a decrease in power.
Anyone else had a similar problem or have any ideas ?
ROBODISCO_20v
Postby rallymazda » Sun Oct 16, 2005 7:05 pm
i somtimes get a burn oil smell but never seen any white smoke, only black when im pushing 7000rpm but thats an other issue
how much oil are you using, im using about 1L per 1500 kms
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby bad20v » Mon Oct 17, 2005 3:06 pm
You guys have just got the typical blacktop symptoms:
Drinking Oil
White Smoke From a hot exhaust
Oil burning smell
etc
I've had the same thing in mine several times, and had the car checked over plenty of times for the problems. There never seems to be a real problem at all so I just leave it. The guys at Toyota just said that they were just typical problems that all blacktops and some silvertops have. :(
Or maybe mine's about to blow up! 8O
:D
Thank-You.
bad20v
Postby ROBODISCO_20v » Mon Oct 17, 2005 4:55 pm
I'm going to get a comp test done, I'm pretty sure it's the head gasket
ROBODISCO_20v
Postby MrOizo » Mon Oct 17, 2005 5:30 pm
when idling and you tap the throtle does the amount of smoke change?
might be valves some how? havent heard of 20v's of any generation having BHG :o
MrOizo
Toyspeed Legend
Postby AceSniper » Tue Oct 18, 2005 1:47 am
valve seals or rings prolly
the stock headgaskits are pritty good
AceSniper
Postby vvega » Tue Oct 18, 2005 6:24 am
yeah id be going with the exhaust valve stem seals
you only get white smoke from oil introduced into the exhaust
v
vvega
Postby phatman3801 » Tue Oct 18, 2005 8:29 am
ive noticed on my blaktop levin on idle there is a constant flow of white somke slowly comming out :?
current project/ride: BZG levin
phatman3801
Postby AceSniper » Tue Oct 18, 2005 11:48 am
If your looking at replacing the valve seals get a "valve grind" gaskit set, as it dosnt cost much more than $200 odd for just valve stem seals, and inc new head gaskit an so-on
AceSniper
Postby Armourermike » Tue Oct 18, 2005 1:01 pm
My black top started blowing a lot of smoke at high reves after I did an oil change. The oil level was high but not at the top of the level gauge. I drained about 250ml of oil out and it hasnt blown any smoke since and hasnt used a drop of oil either, done about 3200ks so far then. Car has done 82,000 ks.
Armourermike
Postby AE111_modifier » Tue Oct 18, 2005 2:49 pm
I just brought a valve regrind gasket kit for my blacktop and it cost $400! Came with head gasket and everything though.
AE111_modifier
Postby AceSniper » Tue Oct 18, 2005 3:09 pm
a ACL kit or permaseal? gen toyota?
I have a Silvertop one sitting here was $250 So if anyone needs silvertop gaskits that are not the same as a blacktop ones pm me :p
AceSniper
Postby AE111_modifier » Tue Oct 18, 2005 3:31 pm
It was a Permaseal kit, brought through a Toyota dealership... they did all the work. I wouldn't trust myself pulling apart the entire engine, I’d probably break something!
AE111_modifier
Postby ROBODISCO_20v » Thu Jan 19, 2006 6:52 pm
Turns out it was the rings. I had a email from a guy in ozzy & he had the same problem with his black top. I stuck some ACL chrome race series rings back in it. They are cheaper & better than genuine ones. So its win, win. Used a genuine gasket set & TRD 0.8mm head gasket. Also replaced the bearings with ACL race series ones while we where in there.
ROBODISCO_20v
Postby vvega » Thu Jan 19, 2006 7:56 pm
ROBODISCO_20v wrote:Turns out it was the rings. I had a email from a guy in ozzy & he had the same problem with his black top. I stuck some ACL chrome race series rings back in it. They are cheaper & better than genuine ones. So its win, win. Used a genuine gasket set & TRD 0.8mm head gasket. Also replaced the bearings with ACL race series ones while we where in there.
did you also do the valve stem seals ??
yours would be the first even engine to smoke white from bad rings if you didntv
vvega
Postby BZG Wagon » Thu Jan 19, 2006 9:19 pm
I experience all the same symptoms (but not quite as bad).
I had it in at Toyota, the mechanic said the cause was a "20v Blacktop Engine". It very common for the valve seals to harden and let oil through.
BZG Wagon
Postby ROBODISCO_20v » Sun Jan 22, 2006 12:05 pm
Yeah I got a full gasket set of mr revhead. So we change ever seal in there. So its better than new now
ROBODISCO_20v
Postby vvega » Sun Jan 22, 2006 12:12 pm
so you dont know what it was.........
if it was the valve stem seals youve replaced them and fixed teh issue
if your gunna ake a diagnosis at least have some grounds for your discovery
v
vvega
Postby ROBODISCO_20v » Sun Jan 22, 2006 12:25 pm
Yeah like I said it was the rings. Dont you read the posts :?:
The oil rings were so worn that they flopped about in the bore. Well not flop but you get what i mean, they didn't have a good seal & there was a gap. Lucky they didn't cause any damage to the cylinder walls & all it needed was a light hone before we put the pistons back in with new rings.
ROBODISCO_20v
Postby vvega » Sun Jan 22, 2006 12:29 pm
ROBODISCO_20v wrote:Yeah like I said it was the rings. Dont you read the posts :?:
you said it was white smoke
if it was then your car is the only one ive ever seen heard of that has made white smoke out the exhaust with bad rings......
white smoke out the breather can happen though from the scorching effect of the flame traving past the rings and down the bores
v
vvega
