tappet clearances for a 2E
Postby rxtoy » Sun Oct 16, 2005 8:31 pm
g/f's car is getting noisier and noisier, will give me something to do while i'm on holiday so i need to know what the tappet clearances are??? anybody got a manual they can have a quick look in for me???
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Crucible » Sun Oct 16, 2005 8:45 pm
This isnt man/specs but 0.25mm In - 0.30mm ex - Hot.
Ive set a few at these settings with no probs... :lol:
TNT
Crucible
Real Life Mechanic
Postby Lloyd » Sun Oct 16, 2005 9:28 pm
Pretty much standard Toyota isn't it? 8 and 10 thou ish
Postby rxtoy » Mon Oct 17, 2005 12:17 pm
cheers, i'll give it a go at that.
are you meant to set them hot? i've only ever done tappets on heavy diesel generators and we did them cold.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Crucible » Mon Oct 17, 2005 6:02 pm
If you set em cold there is a chance the clearance will become less once they are hot due to expansion etc....Well in theory anyways!
If you set em hot the clearance will remain the same.
Good luck :lol:
TNT
Crucible
Real Life Mechanic
Postby fatgtr » Mon Oct 17, 2005 7:52 pm
they clearances actually get bigger when you set them cold believe it or not. due to the fact that the heat is at the bottom of the valve
James
gotta love the punk music
fatgtr
Postby Crucible » Mon Oct 17, 2005 9:22 pm
fatgtr wrote:they clearances actually get bigger when you set them cold believe it or not. due to the fact that the heat is at the bottom of the valve
Good Point ! :lol:
TNT
Crucible
Real Life Mechanic
