4S-FE Chasers??
4S-FE Chasers??
Postby KE25-KP30 » Thu Oct 20, 2005 9:21 am
Hey, I was just looking at another thread, and someone was saying about a 4S-FE Chaser.... im assuming these are RWD, and if they are, are they on the same 30-odd degree angle as the 3S-GTEs? If this is the case, would the mounts interchange?
Also, if they came in manual, what 'box was this??
If they're front-drive, then this is for nothing, but just interested to know :)
Cheers,
Kent
KE25-KP30
Postby KinLoud » Sat Oct 22, 2005 8:59 pm
4sfe Mark II/Chasers etc. They are RWD. All the ones I've seen have the engine mounted upright.
Ken
Ham
021 408 863
Postby KE20 » Sat Oct 22, 2005 10:30 pm
the 4s engines are mounted straight up, the mounts wont changeover, as the 3sgte block has slightly different mounts in the block. if you find a manual one it is a w55. the sx80 and lx80 are solid axle diff, where the jzx81 and gx81 are independent rear. the solid diffs are e series, and the irs ones are g series (6 bolt axles) and e series (4 bolt axles)
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby KE25-KP30 » Mon Oct 24, 2005 10:08 pm
ah, cheers....that clears that one up then! :)
KE25-KP30
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
