AE85coupe wrote:celica is a good way to go 10 inch vented in ta63 etc
you will have to modify your lower arm and steering arm for the balljoint etc. to work (not to sure of exact modifications needed, someone may know)
I can't think of any big brakes that just bolt straight into kp starlets
as for the rear brakes if your going 4agte you will need a bigger diff anyway, so something like an AE86, TA45 or TE71 diffs have disc brakes attached as it is
purple_beasty wrote:Generally swapping struts is not a good option, there are basically no bolt in options that don't do nasty things to your steering geometry. You basically have 2 choices if you keep standard struts (which I recommend) -
1. Mintex pads from RaceBrakes and some slotted rotors, also consider some ducting to help cool the brakes if you give then a really hard workout.
2. Two piece rotor and hat with a bigger caliper on a custom mounting bracket, unless its a race car then probably total overkill.
Personally I would go option 1, will easily pass cert and is considered to be un-modified.
Callum
Users browsing this forum: Bing [Bot] and 13 guests
