Turbo Rebuilds
Turbo Rebuilds
Postby GT4-SUM » Sun Oct 30, 2005 10:57 pm
Does any know if you can rebuild a CT20b with steel internals???????
i have herd a few yes's and a few no's
can any tell me answer????
Cheers Chris
- 06 BF XR8 Falcon
- 04 BA XR6 Falcon | For Sale
- 99 SXE10 Altezza RS200z Turbo | SOLD |
- 94 ST205 Celica GTFOUR | SOLD |
GT4-SUM
Postby Mr Revhead » Sun Oct 30, 2005 11:42 pm
do you mean rebuild a ceramic one with steel bits?
or rebuild the steel ones?
Postby pidge » Mon Oct 31, 2005 12:24 am
IIRC, a "rebuilt" ceramic CT20b has at least the turbine wheel and shaft replaced as a unit (plus the oil-film shaft and thrust bearings replaced), and maybe the "core" replaced outright as well (I can't remember if the Cermic Turbine & shaft can be simply swapped with the shaft for the steel turbine - I'm just barely remembering what was shown on a demo night at Alltech).
The Ceramic trubine is "fused" (for want of a better word) onto the shaft. Removing, let alone installing, the compressor wheel without shattering the turbine wheel is a delicate operation...
Oh, and Alltech Desiel and Turbo (in Wairua, North Shore) are reasonably well recommend.
And change your oil and oil every 5000km.
pidge
Postby Mr Revhead » Mon Oct 31, 2005 8:16 am
yep, ring alltech ask for chris, tell him warwick from bowaters sent you.
or buy a new one off me :wink:
Postby Rob » Mon Oct 31, 2005 6:13 pm
I wa stalking to a guy down at alltech the other day and he reckons that its pretty a waste of time as the ct20 is smaller than the ct26. He recomended that I get a gt25 garret instead
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Mr Revhead » Mon Oct 31, 2005 6:21 pm
i think maybe they thought you meant a ct20 off an old 3tgte
Postby GT4-SUM » Mon Oct 31, 2005 7:33 pm
well either way i was gunna get the ct20b ceramic turbo rebuilt with steel internals???? or i was just gunna find a cheap ct26 and get it high flowed
- 06 BF XR8 Falcon
GT4-SUM
Postby Al » Mon Oct 31, 2005 8:30 pm
Just buy a new ct20b of Revhead. OEM > rebuild.
Al
Postby Phothog » Mon Oct 31, 2005 9:36 pm
Mr Revhead wrote:yep, ring alltech ask for chris, tell him warwick from bowaters sent you.
Thanks for the plug Warrick...
We also have the CT20b Steel shaft in stock...
Or i could rebuild & upgrade the CT26...
Chris
Phothog
Postby KiwiMR2 » Sat Nov 05, 2005 10:47 pm
What does it mean when they say the A/R ratio of the housing is is static?? What is the A/R of a stock ct20b vs the biggest "hybrid" ct26??
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
