by KinLoud » Thu Nov 03, 2005 3:30 pm
Some 4ages have the temp gauge sensor at the pulley end of the engine.
The ecu temp sensor is at the back of the head as you described.
The other sensor near the ecu one might be the cold injector thermo timer switch (causes the cold injector to inject fuel until the the thermo timer switch senses warm water the shuts it off.
Ken
Ham
021 408 863
