16V 4AG water temp sensor help!
Postby aesc » Thu Nov 03, 2005 1:21 pm
Hi,
Can anyone tell me where abouts this is located on 4age/4agzes? I think I may have found it, there are two what look to be sensors close together located on a pipe coming out from the gearbox side of the head (one green and the other is orange or brown). But when I unplugged them I expected the temperature gauge in the dash to stop working but it didnt so that kinda makes me think that either of the sensors I unplugged are not water temp? Can someone point me in the right direction in finding it, or even better post up a pic of where it is?
Also can anyone confirm what size socket it requires to remove it and what size the thread is? Ill be teeing in a water temp gauge and need to know what the NPT/BSP fitting size is.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Ae92typeX » Thu Nov 03, 2005 2:21 pm
where your dipstick is...near the waterpump, its just above there,next to the inlet manifold. 17mm socket/spanner will do the trick. unsure of thread offhand sorry.
Ae92typeX
Postby aesc » Thu Nov 03, 2005 2:38 pm
Ah cool thanks for that, looks like I was looking in the wrong place :oops: I will have a look for it tonight
EX AE101 owner
2013 Ford Focus ST
aesc
Postby CozmoNz » Thu Nov 03, 2005 2:40 pm
i was told the green / orange plugs were them as well (one for ecu, one for gauge)
What are they for then?
Rayne For President!
CozmoNz
Postby Mr Revhead » Thu Nov 03, 2005 2:49 pm
yep ae92 is right the gauge plug is there.
one of the others is the sensor for the ecu. dunno what the other is off hand
Postby Ae92typeX » Thu Nov 03, 2005 2:49 pm
green one is temp ecu afaik, not sure about other one. some 16v's only have the one in that position above the gearbox...maybe the other is the high temp line pressureup switch?...not sure.
Ae92typeX
Postby aesc » Thu Nov 03, 2005 2:56 pm
Yeah thats what I thought too Cozmo, pays to check sometimes.
Warwick, do you know what size the thread is on the sensor?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Thu Nov 03, 2005 3:01 pm
no i dont sorry, looks like youll have to take it out and measure.]
if you want a guess ill say either 10x1.25 or 12x1.25
Postby KinLoud » Thu Nov 03, 2005 3:30 pm
Some 4ages have the temp gauge sensor at the pulley end of the engine.
The ecu temp sensor is at the back of the head as you described.
The other sensor near the ecu one might be the cold injector thermo timer switch (causes the cold injector to inject fuel until the the thermo timer switch senses warm water the shuts it off.
Ken
Ham
021 408 863
Postby gepsk8 » Thu Nov 03, 2005 6:59 pm
its a single wire to if that helps.
gepsk8
Postby aesc » Fri Nov 04, 2005 9:29 am
Cheers people, I still cant find it though :oops: Can someone post up a pic?
Single wire, are you sure? I thought they were two wire?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby aesc » Sun Nov 06, 2005 6:53 pm
Bump
Can someone post up or email me a pic of where it is please?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Jebus » Sun Nov 06, 2005 7:01 pm
Green plug in the casting in the rear of the head is for the ECU, brown one is cold start, this in the pic is water temp for your guage.
Jebus
Postby aesc » Mon Nov 07, 2005 9:13 am
Champion, thanks heaps :D
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Jebus » Mon Nov 07, 2005 10:09 am
Did ya find it alright?
Jebus
Postby aesc » Mon Nov 07, 2005 10:32 am
Yeah, I think I found it right after I posted the request up last night :roll:
Looks like I could be struggling to fit a tee down there though for both sensors, there isnt much room, not on my gtz anyway
Can the sensor be unplugged?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Jebus » Mon Nov 07, 2005 10:38 am
What you need my friend, is one of these bad boys...
http://drivenperformance.co.nz/scripts/ ... roduct=272
Jebus
Postby aesc » Mon Nov 07, 2005 11:11 am
Yeah I know, I'm now thinking that is the easier option. I have PM'd TWSTD about one, I need to know what size sensor they accept before buying though. might need a custom made one
I have tried testing but its kinda hard to tell, but does the water in the top radiator hose warm up with the engine before the car gets to normal operating temp i.e before the thermostat opens?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby CozmoNz » Mon Nov 07, 2005 11:49 am
could always hold each raidator hoses (watch that radiaor fan), and feel which one warms up first :D
CozmoNz
Postby aesc » Mon Nov 07, 2005 12:18 pm
Yeah I kinda tried that, the top hose got warmish before normal operating temp, not as hot as I wouldve thought though
EX AE101 owner
2013 Ford Focus ST
aesc
