Stupid new seatbelts.
Postby pervert » Fri Nov 04, 2005 4:50 pm
My car has 2x new seatbelts in the front, like a lot of replacement belts I've come across, they lock the mechanism ALL the time and you can't pull them out to put them on, and not just on hills either.
A lot of the time you can't get the passenger side belt on, and this is a bit of an issue...
Is there any way to reduce the sensitivity of the locking mechanism or whatever...in short...is there a fix for this?
pervert
Postby Mr Revhead » Fri Nov 04, 2005 4:54 pm
first thing id check is do you have the right ones, and are they mounted at the correct angle.
Postby pervert » Fri Nov 04, 2005 4:56 pm
I've just recently got the car, and they were put in by the previous person...
How do I tell if they are the right ones or not?
pervert
Postby Mr Revhead » Fri Nov 04, 2005 4:59 pm
id be looking to see who the autoliv dealer is in dunedin.
you may need to remove panels and take it in for them to have a look at.
im not an expert on belts, but i do know theres a few toyota ones that look the same but mount on different angles. if the angle is wrong you get that locking that we all hate :x
Postby pervert » Fri Nov 04, 2005 5:16 pm
Thanks for that Mr R, I've only just finally started to wear my belt all the time...and now I've got this car that won't let me...I can't win... :lol:
pervert
Postby rolla_fxgt » Mon Nov 07, 2005 1:32 am
Its Angow compliancing who do the belts in Dunedin. But personally im not happy with their work, i had to have a new belt installed & had to get whole new clicker assembly too, so different colour to factory, but the bit i hate the most is that the belt locks up all the time, so any slight incline & its locked solid.
Im thinking of taking mine out & loading the new webbing onto the old spool & reinstalling that & seeing how it goes. I know its kinda frowned upon, but hey at least i'll be able to breath around corners & up hills.
Is there anyway to losen the sping inside the tensioner so it doesnt bite so quickly?
rolla_fxgt
Postby pervert » Mon Nov 07, 2005 7:53 am
rolla_fxgt wrote:Is there anyway to losen the sping inside the tensioner so it doesnt bite so quickly?
That's kinda what I want to find out... 8)
pervert
Postby sergei » Mon Nov 07, 2005 8:02 am
don't loosen spring, change the angle
