Who is going to be the first caldina into the 12s
Postby fivebob » Sat Nov 05, 2005 7:03 pm
Depends on what type of launch you are getting at the moment. It's going to be pretty much a "suck it and see" approach. I offer the following advice with the proviso that, apart from a few passes on a TZ250 race bike, I've never done any drag racing.
If it's bogging down then I'd set the launch RPM to 500-1000rpm above peak torque, and set the deactivate value < 10 (on the Caldina each VSS pulse = 1/4 wheel rotation ~ approx 0.5m at 100% traction).
If you're traction limited then I'd set it to just below peak torque and set the deactivate value high.
If you're getting a smooth launch then setting it slightly above peak torque and a medium deactivate value.
For the ignition retard value, I would start at -10 and see how fast the boost builds. If you were traction limited before you may want less boost so a value of -5 might be more appropriate.
Bear in mind that you should now have boost at launch so what may have been a smooth launch will now be traction limited.
That is where the deactivate point comes into play. Basically it acts as traction control so that you can't rev any higher than that setting until you've rotated the wheels enough times, set it to a higher value to control wheelspin off the line, lower value if you're not spinning the wheels.
For now I wouldn't bother with power shifting, it's not really good for the drivetrain and is probably worth a lot less than getting the launch correct.
Postby fivebob » Tue Nov 08, 2005 1:51 am
TWSTD wrote:nope - than damn 13.2 again and knocked out in the first round by a 12sec flat mitsi :-(
I see the 13.2 in the race, but how come the qualifying sheet lists you as 12.628 @ 177.6km/h? :?
Postby TWSTD » Tue Nov 08, 2005 7:50 am
That wasnt me - prossibly something to do with the fact that they asked me to change my number between qualifying and racing...
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Adamal » Tue Nov 08, 2005 8:17 am
I still think its do to with the wrong air intake temp reading eh :?
Postby bad20v » Tue Nov 08, 2005 10:23 am
Was it a black Evo 3?
Thank-You.
bad20v
Postby TWSTD » Tue Nov 08, 2005 2:00 pm
no a gold one.
Click here!
TWSTD
Postby fivebob » Tue Nov 08, 2005 2:15 pm
TWSTD wrote:That wasnt me - prossibly something to do with the fact that they asked me to change my number between qualifying and racing...
Just noticed they've got you twice in the results too :? Made it to the third round, but red lighted. Wonder if you get the points for both :twisted:
Postby Inane » Tue Nov 15, 2005 10:11 am
Al wrote:Yeah I do 176km/h+ with est. ~200rwkw on 18psi and a 1220kg rwd car.
so what would you expect from ~xxx kw@tw on 22psi and a 1470kg (minus interior) car?
Inane
Postby Ako » Tue Nov 15, 2005 1:09 pm
Al - hush. An MR2 is a lot different to racing a heavy 4WD.
To put it into perspective - My car weighs 1500kg + with me in it. 16psi, an angry launch and it ran a 12.6, with a 1.7 60ft. The caldina is very similar in power and weight - you lot just need to learn to drive it properly. Even my current VR4 ran a 13.0 @ 105 with me coasting across the line after blowing a hose off midway through 4th, thats even on big HEAVY 18" wheels as well.
Al was right with one thing though - limiter launches do help if your feeling especially sadistic. Netted me consistent 1.7 60fts, every time. Normally I go with flooring it on the first orange (from idle), the dropping the clutch on the last one. Means full boost, around 6000rpm, and a rapid whale.
Try it.
Ako
Postby HELBND » Tue Nov 15, 2005 1:14 pm
Ako wrote:Al - hush. An MR2 is a lot different to racing a heavy 4WD.
Try it.
lol and how many have you broken? :P
HELBND
Postby Ako » Tue Nov 15, 2005 2:25 pm
How many what?
I've only had one decent breakage, and that was a centre diff with 180,000km worth of thrashing on it. Unfotunately it also took out the gearbox it lived inside. Such is life.
No point drag racing if you're not going to try and get the best out of the car, it would be like going in a running race and just jogging for fear of an injury.
Ako
Postby HELBND » Tue Nov 15, 2005 2:31 pm
i was talking about vr4s in general :P
but yeah go hard - no point in being nice to it down the strip :D
HELBND
Users browsing this forum: Bing [Bot], Truenotch and 24 guests
