What turbo do you guys run on your 4agte? How does it run? What turbo would you suggest I use?
Its for a small port 4agze (well, almost a 4agze
Its for street application.
remember"Women wax their armpits and genitals,pul out their eyebrows,pluck their top lip and still wont take it in the arse "cos it HURTS!"
rollas22 wrote:I was running a TD04 frm a GSR lancer on my 4AGTE 20valve silvertop. Went good, lacking in top end tho! Still was producing 10-16psi of boost.
All_Fours wrote:the only problem with that manifold design is the collector...it's going to be way too big and you're going to get massive velocity losses as the gases exit the single pipe into the collector 4 times the size. nice work though, what did you draw it with? solidworks?
