soven wrote:Just kind of curious as to the different kinds of paints available.
I successfully painted my panels before using the small duplicolor cans ($12 each) and normal primer and clearcoat. These lasted without any signs of cracking etc.
Just recently, I thought of respraying everything back to matt black . Considering the high temperature duplicolor paint is the same price and theres no harm trying since I could use it for my calipers , I bought that and the duplicolor adhesion promoter.
Test sprayed on some smaller panels. After a day of drying, it seemed that the paint was ok to be handled but still scratches off easily. Why is that? Would a clearcoat solve that problem? I used clearcoat the last time.
in answer to your question about the paint scratching off... how many coats did you do when you test painted?, did you prime it and wait for that to dry before you did you top coat??? normally paint takes a few days (48 hours) to completley harden.
and if you use clear coat on a matt finish it will end up gloss.
i have just Painted the stereo surround my corolla.
i used a bodytech plastic primer/filler to remove the texture (10 coats) progressivly sand it back to 600 ( 120, 200, 400, 600) two more coats of primer ( sand from 400 --> 1200)
then i did 4 coats of vht quick dry paint. came up like a dream. make sure you prep the plastic very well as any imperfections annoy you (it took me one day to prime and 1 day to do top coat) ill post pics up in an hour (of prepping)
