ollieboy wrote:and sometimes the engine shakes a bit.
AJz wrote:ollieboy wrote:and sometimes the engine shakes a bit.
just out of curiousity.....how much does it shake, like the whole car.
(reason i say this is i remember ages ago when i first had my car, the leads were very frail for some reason, and i managed to snap one, dont ask how, therefore, only firing on 3 cylinders)
also is it constant or sort get slowly worse and then frees up and then worse like in a constant circle???
is it only on startup, like the first 10 - 15 mins?
AJz wrote:it would shake quite a lot if one of the leads had snapped. like the whole car would rock.
my car has a very rough idle when starting it in the morning, ive been told its various things, one was that it needs a new cold start injector and thermal time switch. as i only have this problem on start up, once its been running for say 15 mins its fine.
Is this the same with yours cos this could be the problem.
ollieboy wrote:I took the car for a blat today and noticed that the engine shakes more when its hot than when its cold.
True-No-Turbo wrote:ollieboy wrote:Nah its not losing power aye. Would I get that MBL8 from ripco or something?
Repco do it....or used to, I think its made by Promar?
TNT
