4K missing.
4K missing.
Postby pervert » Mon Nov 14, 2005 8:53 am
I have a problem where my 4K has a bad miss.
This is a problem that happens maybe 4 or 5 times (sometimes more), in a 10 minute drive, and is a sudden miss, sometimes by itself, and sometimes in a series of 3-10 odd times...
I'm just looking for anyone to suggest any possible things to check, the following is what has already been checked/adjusted/replaced if possible;
Carb, fuel pump, plugs, points, leads, HV lead, fuel filter, distributor cap, coil pack, coil/distrib connections, timing, and I'm sure others that I can't remember...
Thanks.
pervert
Postby DVLRCR » Mon Nov 14, 2005 9:39 am
did you check your vacum advance? maybe that has something stuck in it thats making it move around...?
just something else to check... havent had this problem myself
DVLRCR
Postby Big pun » Mon Nov 14, 2005 9:44 am
I had a simular problem with my old 4k..
took me ages to figure it out, the leads seemed fine but then I put on a spare set I had & took it for a drive, problem solved.
so if you haven't already, replace the leads
Big pun
Postby fuel » Mon Nov 14, 2005 12:29 pm
Did you check the gap on the spark plugs? Should be 0.7~0.8mm.
LOUD NOISES!!!
fuel
Postby rollas22 » Mon Nov 14, 2005 12:38 pm
Had the same problem on my 4k in my Starlet Sprint, would be fine on cold start up and drive, once got a little warm would miss... so replaced the plugs and leads and it was fine.
Check the temp range of the plugs? could be using the wrong plugs maybe
KE-Corolla's for life!!!
rollas22
Postby overcast » Mon Nov 14, 2005 2:43 pm
Plugs for a 4k should be BP5ES (ngk or equivilent)
overcast
Postby vvega » Mon Nov 14, 2005 2:49 pm
hha check the points again :D
if they have pitting replace the condensor on the side of the dizzy :D
v
vvega
Postby pervert » Mon Nov 14, 2005 2:51 pm
vvega wrote:hha check the points again :D
v
Pretty sure we got that sorted, it's got new points with the dwell set right...
This mismatched spark plug idea is a good one, I'll have to check that!
pervert
Postby Virtual Genocide » Mon Nov 14, 2005 8:52 pm
overcast wrote:Plugs for a 4k should be BP5ES (ngk or equivilent)
Are you sure?
If the engine's standard he should be using the larger electrode verisons. Which is what toyota specify. The BP5EA-L or the BRE527Y IIRC
In saying that i use the BPR5EY in my 4k, but it has higher compersion etc etc :roll:
Pervert: Have you done a compresion or leakdown test latley? Might be a good idea to check everything inside is sweet. 8)
Phil
Last edited by Virtual Genocide on Mon Nov 14, 2005 9:25 pm, edited 1 time in total.
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby Vertigo » Mon Nov 14, 2005 9:14 pm
yep, i recently had this on my 2A. try the condensor, leads, and ignition coil.
Vertigo
Postby Jebus » Mon Nov 14, 2005 9:17 pm
Electronic ignition would make all these troubles go away :D
Jebus
Postby Virtual Genocide » Mon Nov 14, 2005 9:33 pm
Jebus wrote:Electronic ignition would make all these troubles go away :D
:roll: Not another one.
Waste of time if you want reliability IMO
Electronic ignition on the 4k (etc) has a tendency to blow the ignitor. Not to mention the advance curve *shudder*
Virtual Genocide
Postby Ae92typeX » Mon Nov 14, 2005 9:51 pm
youve done points, but have you replaced the condersor?
Ae92typeX
Postby Vertigo » Tue Nov 15, 2005 9:48 am
btw, it will get REALLY bad if you ignore it. eventually it would jutter and stall in unfortunate places. and then not start.
Vertigo
Postby pervert » Tue Nov 15, 2005 10:16 am
Vertigo wrote:btw, it will get REALLY bad if you ignore it. eventually it would jutter and stall in unfortunate places. and then not start.
Haha, funny you should say that!!!
That happened last night on the way home, took ages to start again... 8O
So you suggested condenser, leads, and ignition coil? 8)
pervert
Postby Jebus » Tue Nov 15, 2005 1:04 pm
Oh ok, havnt had any problems with it in the past ive found it to be superb had a 5K running electronic and didnt ever give me a single fault.
Also Pervert my girlfriends 2A was doing exactly what yours is doing, it got to the point where it cut out at intersections, wouldnt start, had no power etc. We replaced the dizzy with one from a 4A (electronic with internal coils) and it ran perfect ever since, and had more power than other 2A's ive experienced. On hers we replaced EVERYTHING similar to what youre doing, but nothing seemed to fix it until we went to electronic ign.
Jebus
Postby Vertigo » Tue Nov 15, 2005 8:34 pm
i must remember that.
Vertigo
Postby overcast » Wed Nov 16, 2005 3:04 am
Are you sure?
Yes I am sure, I just finished my job of 3 years at a Automotive Parts Distrubitor in CHCH and I owned a high compression 4K till about 2 weeks ago.
There is little differnece between a BP5EA-L and BP5ES and I havent found one place that actually sells a BP5EA-L plug.
Check the leads, dist cap, condensor, plugs, also mite be worth replacing the fuel filter and clean the carb.
overcast
Postby pervert » Wed Nov 16, 2005 7:38 am
overcast wrote:Check the leads, dist cap, condensor, plugs, also mite be worth replacing the fuel filter and clean the carb.
Done all of those things multiple times, replaced the condenser yesterday with no improvement...
pervert
Postby Vertigo » Wed Nov 16, 2005 8:29 am
its probably a combination of the things i mentioned, knowing electrical parts.
Vertigo
