4K missing.
Postby pervert » Wed Nov 16, 2005 8:31 am
Vertigo wrote:its probably a combination of the things i mentioned, knowing electrical parts.
I've tried different leads and coil as well... :?:
pervert
Postby Vertigo » Wed Nov 16, 2005 9:29 am
hmm well thats me beat then. then again, the distributor was replaced as well.
althought before you replace it, try cleaning the points in the dizzy.
Vertigo
Postby pervert » Wed Nov 16, 2005 9:51 am
I think I'm just going to put a whole new 4K in it... :lol:
pervert
Postby Dell'Orto » Wed Nov 16, 2005 12:47 pm
It'd be cheaper :D
Postby pervert » Wed Nov 16, 2005 1:05 pm
Mmm, Boost wrote:It'd be cheaper :D
Sure would, especially when I have a spare with a mild cam in it sitting on the floor... :lol:
pervert
Postby overcast » Wed Nov 16, 2005 1:13 pm
Is the engine actually getting fuel? Could be the fuel pump or is the air filter badly blocked? Which would cause it to be starving for either fuel or air or both.
overcast
Postby pervert » Wed Nov 16, 2005 1:23 pm
overcast wrote:Is the engine actually getting fuel? Could be the fuel pump or is the air filter badly blocked? Which would cause it to be starving for either fuel or air or both.
Have replaced the fuel pump, and it's got a brand new Ramflo ( :lol: ) on it... 8)
pervert
Postby t0ms » Fri Nov 18, 2005 5:43 pm
have you got an aftermarket tacho or anything running off the coil????
i have heard of them sometimes giving grief
t0ms
Postby pervert » Wed Nov 23, 2005 1:46 pm
t0ms wrote:have you got an aftermarket tacho or anything running off the coil????
You sir, are my new personal hero... 8)
After replacing and testing EVERYTHING, disconnecting the tacho I had installed has stopped the miss... 8)
pervert
Postby Virtual Genocide » Wed Nov 23, 2005 6:51 pm
:o that right :o
will have to remember this. Was it connected wrong?
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby pervert » Thu Nov 24, 2005 7:52 am
Nope, it was just hooked up to the negative side of the tacho, it's one of those little 2 inch cheap Trisco ones...
Put it this way, it used to ALWAYS miss at least twice in a 5 - 10 minute drive, and after disconnecting it, it hasn't missed the last 4 times I have driven it for 10 or so minutes, so fingers crossed. :D
pervert
