Vertigo wrote:its probably a combination of the things i mentioned, knowing electrical parts.
I've tried different leads and coil as well...
overcast wrote:Is the engine actually getting fuel? Could be the fuel pump or is the air filter badly blocked? Which would cause it to be starving for either fuel or air or both.
t0ms wrote:have you got an aftermarket tacho or anything running off the coil????
i have heard of them sometimes giving grief
