Mike- wrote:how should i fix it?
TrouserFxGt wrote:Mike- wrote:how should i fix it?
By fitting the wheel and torquing the wheel nuts back up. Problem solved. Don't forget to change your 'steering arm' while you are there.
All_Fours wrote: The correct information
Silent Knight wrote:None of that should be happening.
If it is doing all of that the way that you described I wouldn't even ever considering driving the car out of my driveway...
All_Fours wrote:don't listen to anything said so far
brake rotors are held on by the wheel being bolted on, and to remove them you just take the caliper off and pull them - sometimes they sieze onto the center spigot, but what you've described is exactly how they should be!
the wheelstud movement relative to the disk is normal too.
the wheel studs are attached to the hub, not the disk.
seriously, everything you've described is perfectly normal.
Mr Revhead wrote:um.. the wheel studs should not be moving at all!!!
Mike- wrote:i the wheel studs were loose (they could move left to right within the holes in the brake rotors.
Mr Revhead wrote:ah i see what your getting at, and i read it as studs are moving as well, not just the disc....
at least thats how hes explained it.
-Mike wrote:also are the wheel studs meant to move around in the hub??
