ECU or other computer memory loss after battery disconnected
Postby Di » Thu Nov 17, 2005 1:06 am
Just wondering any particular make/model/year need to be aware of when doing battery replacement
Daily driver: BOMEX AE111 LEVIN BZ-G
Projects: 83' Zenki AE86 TRUENO GT-APEX, 85' Kouki AE86 TREUNO GTV
My Trademe listingsPM me if keen on anything and I'll do a better deal.
Di
Postby IH8TEC » Thu Nov 17, 2005 11:52 am
it's not gona wipe the maps in them, will reset it as such, so if you had fault codes come up, disconnect it, ideally after you check what codes it was, reconnect, after say a minute, and there will be no fault codes. everything should be fine.
happends with most cars that have computer in them,
Postby CozmoNz » Thu Nov 17, 2005 12:05 pm
just on a sidenote, what happens with Eboost's Eboost2's, other EBC's, Vafc's Safc's etc and other "piggy back" controllers?
What if you change the battery while you have those, do they reset, do they somehow save their maps yada yada?
Rayne For President!
CozmoNz
Postby IH8TEC » Thu Nov 17, 2005 12:10 pm
hmm, i doubt that it would affect the safc's etc, but posibbly the boost controllers, unless they store their settings, so next time its on it works like it used to?
Postby Ae92typeX » Thu Nov 17, 2005 1:49 pm
you can connect a small battery (eg 9v) to the terminals when changing to store memory to things that do loose them (e.g. mainly on stereos). But yea, aside from that wont be a problem with any standard car.
Ae92typeX
Postby loose_unit » Thu Nov 17, 2005 6:57 pm
The eboosts wont lose their memory, as they only connect to the acc for their power source. Otherwise they would lose their memory everytime you turn off the car.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
