silvertop 20v with oil catch can
Postby deaf_rattle » Sat Nov 12, 2005 9:28 pm
I presume i just whack it inline with the line from the cam cover to the intake pipe?
Any issues with doin this?
Also i am thinking in the long term, of installing a fibreglass ae92 gtz bonnet scoop and a top mount oil cooler, any issues with doin that?
20v into ae92 fxgt
Postby Mr Revhead » Sun Nov 13, 2005 11:25 pm
i found the catch can a lot more effective when its taken from the hose thats off the back of the cam cover to the inlet manifold. just make sure you block off the hose to the inlet properly
i run a can with a filter on top and feed both lines into it, catchs oil, but also a huge amount of water....
Postby AceSniper » Mon Nov 14, 2005 3:00 pm
look at my profile pic think u can see how mines done?
run hose off pcv to the can, block the other side of it with a pipe an bolt onto the inlet, run a hose from the end of the cover to the can, block the hole into the intake hose
AceSniper
Postby Mr Revhead » Mon Nov 14, 2005 3:03 pm
hard to see, sounds exactly like mine
Postby ROBODISCO_20v » Sat Nov 19, 2005 3:33 pm
Any one else got some pics??
ROBODISCO_20v
Postby AceSniper » Sat Nov 19, 2005 8:22 pm
ill get more on sunday if need be?
AceSniper
Postby deaf_rattle » Sun Nov 20, 2005 8:30 am
yeah, that would be great
cheers man
Postby AceSniper » Sun Nov 20, 2005 11:45 am
AceSniper
