IH8TEC wrote:what gearbox and gearing you got. if it was me i'd be hoping for at least 14's from what i've seen with a couple of others. especially considering race tyres, stripped, lsd etc
just my 2c, but good to see you get out there,
Rick wrote:Tims "gdsup" supercharged AE-86 ran a 13.7 1/4 mile. He has changed his setup now so it could be running faster times
JT wrote:What 60ft times and what trap speed are you getting? These are just as important as your ET.
Drifter4ag wrote:hey man ... something not right there ...
ae86 with stock engine just headers and filter can get mid to high 15s with semi decent tyres like grid 2 or similar.
your trap speed indicates that something is up as 140k is pretty slow for a 4agze
beeker wrote:
With what mods ?
Also, i'm told the drop off at the top of my chart is normal for the AE101 4agze ECU ?? Sound right ??
beeker wrote:How do you think the Dyno chart looks ? Normal or off ?
JT wrote:beeker wrote:How do you think the Dyno chart looks ? Normal or off ?
Your dyno chart looks ok. 140k is a low trap speed though, did you keep your foot right to the floor till definately passed the timing beam?
What rev's are you changing gear at?
Drifter4ag wrote:the power your ze is putting out just seems low .. but lots of them are for some reason .... when you think that one of our bluetops with headers etc will put down 82-88kw@wheels on that dyno your 12kws for 8psi of boost is pretty poor. My first suggestion would be to either buy a custom manifold off Tim or make yourself a RWD cut shut job standard manifold ...
but yeah .. a 4agze in ae86 stock should do 14s
Users browsing this forum: No registered users and 156 guests
