3TGTE - Detontation under load
Postby DIRTYDX » Mon Nov 21, 2005 9:05 pm
Just finished putting a 3tgte in my KE36 and having some boost issues,once she get to around 4500/5000 rpm she seems to start pinging/violent jerking,with my little knowledge im putting this down to her leaning out,when this happens shes showing around 7.8 psi (standard boost for a factory 3T) and then when you change gear she goes up to 10psi before quickly dropping back to 0 so i dont think shes overboosting,anybody had this problem before or know anybody i could get hold off that could help me out,im using the standard ecu/knock computers and the factory pressure switches (overboost/fuel enrich)
DIRTYDX
Postby YeMs » Mon Nov 21, 2005 10:13 pm
chuck a fuel pressure gauge on it. just run a T in the line, go buy urself sum more fuel line and a fuel pressure gauge (if they sell them out in the sticks were u are :P) an see if its dropping fuel pressure. i assume your running 96... timing? lol u havent advanced the arse of it have u?
Your local Hybrid Elite tech
YeMs
Postby DIRTYDX » Mon Nov 21, 2005 10:26 pm
Yea was next thing to check on my list,fuel setup wise i think im alright,im using 3/8'' from a 96 octane fulled tank in2 a standard ST142 corona fuelpump then 5/16'' straight to the fuelrail with a steel bodied inline filter along the way and just using the standard KE36 1/4'' line as a return,similiar setup to yours?
DIRTYDX
Postby DIRTYDX » Mon Nov 21, 2005 10:31 pm
And timing wise shes setup at factory spec 12 degrees BTDC....
DIRTYDX
Postby Ako » Tue Nov 22, 2005 9:18 am
Sure its a fuel issue and not an ignition problem? That can cause the jerking / backfiring your describing.
Ako
Postby phrogmodz » Tue Nov 22, 2005 8:07 pm
sounds very similar to problems iv incountered
in two conversions iv done with 3tgte"s
they have a tendancy to blow out the spark
if the spark plugs are gapped at more than .8
-regaping made a huge differance on both cars
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby YeMs » Tue Nov 22, 2005 10:28 pm
um yeh 3/8 fuel line, inline vr4 fuel filter, vl commode pump, surge tank, high flow low pressure plump. standard line is the return. um yeh like said check the spark plug gap.
YeMs
Postby DIRTYDX » Wed Nov 23, 2005 9:07 pm
Phrogmodz: Yea im using brand new NGK BP7ES plugs and the gap is around 0.7 mm..do they sound like the sort of plug i should be using? What sort of symptoms were your 3tgtes having when u had trouble
Ako: By 'igniton problems' what should i be checking for,shes getting spark and she runs mint all the way up till around 4500 rpm + idles fine,wat else should i check for ??
Any other ideas people? im picking up a gauge tommorrow nite so checking fuel pressures next on the list
DIRTYDX
Postby phrogmodz » Thu Nov 24, 2005 8:41 pm
both the ta22 and the ke35 had identical symptoms
missing under load on boost and throwing unburnt
fuel out the back (black smoke).
id recheck the gaps and set to .8
then resistance check the leads-sounds like somthings
breaking down under load.
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
