Toyota Levin Ae111 Pinging Problems. Anyone Who Can Help???
Postby demis » Tue Nov 22, 2005 9:46 pm
hi
i have a ae101 bz touring wagon (black top 20v)
i have the same problem i have tryed that timing like has been sugested
it made it a little better but did not fix it
i cant work out what the hell is causing it
car has new cambelt just been serviced new spark plugs oil filter all that shit
running it on 98
only ever dose it for a short while after starting it , and not all the time
maby the 20 v just dont like our shit petorl in nz
i might try some outane booster next fill up see if that makes any diffrance
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby Ae92typeX » Tue Nov 22, 2005 10:35 pm
demis wrote:...
as in each time you start it, or just when it's cold?
Ae92typeX
Postby demis » Thu Nov 24, 2005 5:58 pm
it seams to do it most of the time when you first start it when its cold
but it can still do it when it warm and you just start it
that other thing that is rearly starting to piss me off is when you have your foot the gas pedal then take it off the car jerks , its as if the throttal butterflys are bouncing
it dose it even when you take your foot off rearly slowly
any one have any idear as to what could be causing this??
i have driven silver top corolla's that have done this to
demis
Postby matt dunn » Thu Nov 24, 2005 9:29 pm
demis wrote:it seams to do it most of the time when you first start it when its cold
Yes I know this problem. My car (AE111 Blacktop BZT) does exactly the same when cold.
I have not chased the problem too much but I believe the only way to fix it is to fit a Catch can to the breather to prevent the fumes from getting into the intake.
I put it down to when it is cold the pistons have not expanded and there is extra blow by in the engine, and as most people know the oil fumes cause detonation which the knock sensors detect's and retards the timing.
It is the retarding and advancing of the timing that you feel.
So in summary, Fit a Catch can.
Matt
Postby demis » Fri Nov 25, 2005 8:03 pm
hi i supose that could be posible but if that was the case then would expect to see oil resadue in the intake piping wouldnt you ???
mine was rearly clean when i got it from japan and after doing 7,000 km in it there is still no oil on the pipes
it has also not used a drop of oil in 7,000km running it on semi synthectic
if i were to fit one of thoes small filters to the breather that would do much the same thing as the oil catch can wouldnt it
i will give that a try
demis
Postby matt dunn » Fri Nov 25, 2005 9:54 pm
demis wrote:hi i supose that could be posible but if that was the case then would expect to see oil resadue in the intake piping wouldnt you ???
You may not see oil as it is the oil vapour that is the problem not actual oil.
If it is a blacktop you can disconnect both the pcv hoses and leave them open to atmosphere for a short time to try.
matt
Postby CozmoNz » Fri Nov 25, 2005 10:00 pm
the jerk on throttle lift off, last i heard about solving it was cleaning the butterflys (grime and shit building up on them).
Rayne For President!
CozmoNz
Postby matt dunn » Sat Nov 26, 2005 6:23 pm
CozmoNz wrote:the jerk on throttle lift off, last i heard about solving it was cleaning the butterflys (grime and sh*t building up on them).
Possibly,
The fault I was referring to was the car running like crap when cold.
matt
Postby demis » Mon Nov 28, 2005 6:15 pm
ok i will try with the hose disconected far a short while
i was about to ask wht the seckond pipe as this seems to have quite a bit of oile shit in it
thanks
demis
Postby demis » Sun Dec 04, 2005 9:37 pm
i tried disconnecting both the pcv hoses and leave them openwith filters on the ends of them for 2 days
it did not make any diffrance
dont rearly know what to try next ???
demis
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
