4wd conversion, surely it can be that easy?
Postby neon_spork » Fri Nov 25, 2005 12:20 am
There is an interesting auction on trademe where someone is selling a collection of parts that they were going to use to convert an AE92 or AE101 to 4wd + 4agze.
They recon there wouldn't be any fabrication required, has anyone tried this before? Surely its not as easy as they make it sound.
http://www.trademe.co.nz/structure/auction_detail.asp?id=41426429
neon_spork
Postby Alex B » Fri Nov 25, 2005 12:23 am
Well snce there is no such thing as a rear diff for ae92 im doubting it, possibly be an ae95 diff, but it has a diffrent chassie code for a reason....
Postby Alex B » Fri Nov 25, 2005 12:24 am
Oh and ae101 IRS dont exist either :lol:
Postby mr pad » Fri Nov 25, 2005 8:48 am
pyro_sniper2002 wrote:Oh and ae101 IRS dont exist either :lol:
ae101 dont have irs? haha.
mr pad
Postby RomanV » Fri Nov 25, 2005 9:10 am
You're kidding, right? :?
Postby CozmoNz » Fri Nov 25, 2005 9:51 am
*fits flame suit*.... ur fked... haha.
i do agree with the ae92 rear diff comment, anything with a 5 on the end is 4wd... so yeh, ae92 cant possibly have a rear diff.
no its not that easy at all, its ALOT of work (ask matt dunn), if you want a rwd, go buy a supra, a celica etc, or a silvia / skyline sort of thing.
converting a fwd to rwd will never handle the way a silvia and such will.....
less you spend heaps ;) hahahah.
Rayne For President!
CozmoNz
Postby Fraud » Fri Nov 25, 2005 10:20 am
Must remember though that some one has converted an ae101 wagon to rear wheel drive.
With a rotor in it...
Fraud
Postby Mr Revhead » Fri Nov 25, 2005 10:30 am
ffs
some corolla wagons are live axle rear.....
all other ae101s etc are IRS.
this has been talked about many many times. i beleive a carib or two have been done....
if to want to do it, just buy a 4WD version and fit a 4agze.... there is doubt about the drive line strength though....
is not worth pissing around trying to make a fwd version 4wd....
the floor pan is different... think prop shaft and suspension mounting...
and not all 4wds end in 5......
Postby Malcolm » Fri Nov 25, 2005 11:59 am
Mr Revhead wrote:if to want to do it, just buy a 4WD version and fit a 4agze.... there is doubt about the drive line strength though....
I looked at a 4wd corolla wagon that had an E56F I think it was - which should be pretty strong (depending on how beefy the transfer is)
This is entirely correct - if you want a 4wd then just get one - they are available. A 4wd ae101 would probably be nearly as heavy as an st185 ;)
Postby Mr Revhead » Fri Nov 25, 2005 12:03 pm
the gear box itself will be fine, its a toyota box!!
it was more the transfer i was thingking of....
Postby Malcolm » Fri Nov 25, 2005 12:31 pm
well judging by what I've seen on most E series boxes, you could probably use a gt-four transfer case without too much hassle, which is fairly beefy.
Postby Mr Revhead » Fri Nov 25, 2005 12:38 pm
hmm dunno... a 4agze would break one..... :P
so ... drive train sorted then.... :D
still, staring with a factory 4wd version is the way
Postby Leon » Fri Nov 25, 2005 12:54 pm
Because a rear wheel drive *anything* is better ahuhuhuhuhuhuhuh boe put a rotor in it au.
Postby CozmoNz » Fri Nov 25, 2005 12:58 pm
Mr Revhead wrote:and not all 4wds end in 5......
/hails revhead.
Sorry captian :).
CozmoNz
Postby Alex B » Fri Nov 25, 2005 5:08 pm
Was tired was meaning they dont have a rear diff, let alone an irs diff. :oops:
EDIT: E55F5 in mine, arnt they compatiable with gt four box internals or somehitng....(im probly wrong)
Postby TrouserFxGt » Fri Nov 25, 2005 7:52 pm
The diesel corolla wagon has a leaf sprung rear diff. If you put a 101 on a hoist you can see where it can be mounted. There is plenty of room back there.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Truenotch » Fri Nov 25, 2005 9:44 pm
But where would the driveshaft go?
Truenotch
Postby dohca » Sun Nov 27, 2005 7:22 pm
Truenotch wrote:But where would the driveshaft go?
in the bin
dannyp
dohca
