DAIHATSU 3cylinders!!!!
Postby bluemaumau » Tue Nov 29, 2005 7:58 pm
ok i know this is toyspeed = toyotas but my m8 got a GTti and i doubt theres a forums for daihatsu. :lol: ok so if any1 knows the best mods or have had any experiences it would be much appreciated.
p.s we mainly wanna know how to raise the boost past boost cut(15psi) cuz these mighty 3 cyclinders have forgies! :twisted:
thanks
Postby vhpacer » Tue Nov 29, 2005 8:04 pm
http://www.daihatsu-drivers.co.uk/forum/5
Theres a forum but there aint much there.
vhpacer
Re: DAIHATSU 3cylinders!!!!
Postby 1598cc » Tue Nov 29, 2005 8:13 pm
bluemaumau wrote:ok i know this is toyspeed = toyotas but my m8 got a GTti and i doubt theres a forums for daihatsu. :lol: ok so if any1 knows the best mods or have had any experiences it would be much appreciated.
thanks
extra injectors, slightly retarded timing , fcd.. 20psi no more.. otherwise a aftermarket ecu.
ive had 3, one ran 24-28psi on a drs computer. went nuts.
http://forums.eis.net.au
http://focusdevelopments.com.au/daihatsu/index.php
1598cc
Postby bluemaumau » Tue Nov 29, 2005 8:25 pm
thanks vhpacer.
um its already got a extra injector.
i was told that a fuel pressure regulator and defender would let higher boost be run. but i have no idea how that would help.
plus aftermarket ecu a bit much at the moment. :cry:
Postby snwtoy » Tue Nov 29, 2005 8:41 pm
www.daihard.org
I want one too.
snwtoy
Postby bluemaumau » Tue Nov 29, 2005 8:47 pm
snwtoy wrote:www.daihard.org
I want one too.
yea bro they mean little toys ay. :lol: 8)
so far hes got 16" wheels, 2 skyline side mounts welded together and front mounted, pod, and a clamped factory BOV. surges like a daddy. haha soon to get full exhaust and a mod too enable more boost, which is were you guys come in! :D
Postby snwtoy » Tue Nov 29, 2005 8:57 pm
They don't have a factory bov, so that's probably why the surge.
GTX turbo's are a good upgrade, fuel cut defender, and up to 20psi boost.
Those mods, with sorted suspension should be good for low 14s.
snwtoy
Postby Ako » Tue Nov 29, 2005 10:02 pm
Fond memories of my honda city turbo.... God tiny cars with big boost are a hoot to drive!
Can do you a fuel cut defender for $160, thats the gizzmo one. Can probly get something else cheaper, but thats the new part price for it. PM me if you want it.
Ako
Postby bluemaumau » Tue Nov 29, 2005 10:22 pm
snwtoy wrote:They don't have a factory bov.
well this one does. or maybe its a shitty aftermarket one. lokks old and factory tho.!
dont all cars have BOV standard!!!!!! 8O
um AKO yea could be keen soon. gotta wait for a pay check ill pm u tho when i want it. do you know of any cheaper ones? :)
Postby EVL GSXR » Wed Nov 30, 2005 6:49 am
Naa they don't have a BOV Standard..
My mate has one and he love's it.. So far he has run a 14.7 1/4 and the only Mod's were a Apexi Pod Filter, No Cat, 21psi.. He did have a T3 off a GTS25T sitting there to mount up last time was round there :D As well as a Full Exhaust :lol: ..
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby bluemaumau » Wed Nov 30, 2005 9:03 am
can you ask him how he ran 21psi. cuz we get boost cut @15psi
Postby EVL GSXR » Wed Nov 30, 2005 9:08 am
bluemaumau wrote:can you ask him how he ran 21psi. cuz we get boost cut @15psi
Sweet will do sure he's just running a lil board he got made up few year's back that take's out the Boost Cut but will check..
Doesn't handle to bad either now that he lowered it and I gave him my old Detomaso Rim's for it look's pretty kool :D ..
www.lowndvs.co.nz
EVL GSXR
Postby Alex B » Wed Nov 30, 2005 12:19 pm
i would say the fuel cut works off a resistance reading, so with a resistor in the right place it would cost you all of about 50cents to mod.
Postby Mr Revhead » Wed Nov 30, 2005 1:34 pm
yes very cool little cars....
the factory ecu has its cut at 16psi..... i ran 15 on mine with no issues. other than we couldnt get the thing to run less than 12!!!
when i had mine i came across an website that had a few guys running 200hp with nothing other than turbo, injector and intercooler upgrade, oh and ecu, but i cant recall if they tricked the ecu or replaced it....
many a vtec suffered a horrible caning from my GTXX :D
Postby EVL GSXR » Wed Nov 30, 2005 1:38 pm
Mr Revhead wrote:yes very cool little cars....
You mean GTti or did you have an earlier model one??
www.lowndvs.co.nz
EVL GSXR
Postby Mr Revhead » Wed Nov 30, 2005 1:42 pm
nope, 1990 g100 GTxx. as far as i could find out they were a limited run, all black with silver/grey body kit.
had a few different parts from the GTti, bigger C/Vs and supposedly a bigger turbo and different ecu, possible they were a F2 rally homologation car... but i could never find anything concrete to support that.
Postby Santa'sBoostinSleigh » Wed Nov 30, 2005 1:45 pm
damn all this talk makes me want a little shitter i can thrash the living arse off!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby EVL GSXR » Wed Nov 30, 2005 1:46 pm
Santa'sBoostinSleigh wrote:damn all this talk makes me want a little shitter i can thrash the living arse off!
I thought you had a Caldina??
Joke's fella :D :lol: :D :lol:
www.lowndvs.co.nz
EVL GSXR
Postby snwtoy » Wed Nov 30, 2005 5:18 pm
Mr Revhead wrote:nope, 1990 g100 GTxx. as far as i could find out they were a limited run, all black with silver/grey body kit.
Only difference between a GTti and a GTxx was the engine code. CB80 vs CB70. No other differences whatsoever anywhere. Turbo, cvs, ecu, everything is identical.
The boost cut is controlled by a voltage reading sent from the map sensor, which also controls fueling. A simple resistor will not do the trick (nor will bleeding the feed to the map sensore :oops: ), you need a few more bits to allow the boost to keep increasing, but the voltage level needs to rise to a fraction before the cut level in order to maintain fueling. An FCD as has been mentioned earlier is the solution for this - although $160 is a lot to pay for something you could build with parts from DSE for under $20.
snwtoy
Postby scotts2hot » Wed Nov 30, 2005 6:46 pm
I always thought the GTxx was lower spec. No options and lightweight.
scotts2hot
Users browsing this forum: Bing [Bot] and 20 guests
