changing gauge cluster?
Postby fx gt » Thu Dec 01, 2005 12:41 pm
in the wagon theres a fxg gauge cluster.i want to put a fxgt gauge cluster in with the extra gauges.is there any way of swapping around the wiring to put the fxgt gauges in?
sam
fx gt
Postby Ae92typeX » Thu Dec 01, 2005 2:03 pm
with a bit of work it shouldnt be a problem. Ideally you will want a wire diagram for each and be prepared to run some additional wires obvously.
Also, depending, you may need to check the sender units as sometimes these are changed also.
Ae92typeX
Postby fx gt » Thu Dec 01, 2005 4:18 pm
Ae92typeX wrote:with a bit of work it shouldnt be a problem. Ideally you will want a wire diagram for each and be prepared to run some additional wires obvously.
do the wiring from a fxgt gauger cluster have a conection plug?me thinking i could just swap the conection plugs around?
fx gt
Postby fx gt » Thu Dec 01, 2005 5:29 pm
searched around with the looms i got and it appears i can just switch the two.bloddy good :)
fx gt
Postby Ae92typeX » Thu Dec 01, 2005 6:20 pm
but extra gauges for that may not be hooked up (or may be, depending on what they are)
Ae92typeX
Postby fx gt » Thu Dec 01, 2005 6:56 pm
Ae92typeX wrote:but extra gauges for that may not be hooked up (or may be, depending on what they are)
oh shit :P
well lets hope they are cause the wiring loom is still on the motor im putting in.
fx gt
