in the wagon theres a fxg gauge cluster.i want to put a fxgt gauge cluster in with the extra gauges.is there any way of swapping around the wiring to put the fxgt gauges in?
sam
Ae92typeX wrote:with a bit of work it shouldnt be a problem. Ideally you will want a wire diagram for each and be prepared to run some additional wires obvously.
Also, depending, you may need to check the sender units as sometimes these are changed also.
