Silent Knight wrote:Inane wrote:really?
hrmm... Id never get extensive work done somewhere which didnt warantee their work...
Yea but if they waranty their work they're going to be giving a waranty on workmanship and parts supplied and installed.
They didn't supply the block/crank and they didn't install it therefore they won't cover any damage made to it.
evil_si wrote:from experience a rod out the side is usually from an over rev!
according to raw,
the job was sent to the nz haltec agent who did the install and tuning.
SUBARUCONVERT wrote:Silent Knight wrote:Inane wrote:really?
Thats not really correct, If u came in for some work, then they went for a test and thrashed it and blew the gear box it would be there problem, they would of killed his engine thru incopitance rather than the engine already having a fault, if u took them to court they would have prove there was a problem with the engine before hand, how are they going to do that? and if there was a problem why did they still continue to drive and tune the car?
caldinagtt wrote:Full 3 inch exhuast straight through
38mm tial wastegate
turbosmart super sonic bov
walbro fuel pump
rising rate fpr
pod filter
air con ditched
frount mount intercooler
oil catch can
up specd standard turbo
and a Haltech e6x computer road tuned on 15psi.
Raw_Motorworx wrote:thanks for the negative feed back, we were working with your father to try and resolve the issue.
