Turboing silvertop
Turboing silvertop
Postby trueno_20v » Thu Dec 01, 2005 5:27 pm
I want to turbo my ae101 trueno with silvertop 4age, just wondering if it will run with standard ecu on approx 6 psi untill i get something after market? My set up will be- Custom made turbo manifold probably made by ''action dan'', tial 38mm external wastegate, t3 turbo off rb20det and 600x300 fmic etc also seems the silvertops hi comp what sort of boost will be safe for it all standard internals etc? cheers
ADMIN EDIT: signature too large
trueno_20v
Postby Silent Knight » Thu Dec 01, 2005 5:33 pm
User the SEARCH button.
Google will also have all of the answers easy peasy...
This Topic has been covoured 10x millions times before.
Silent Knight
Postby trueno_20v » Thu Dec 01, 2005 5:35 pm
I did search but couldnt find much about if they run on standard ecu low boost etc.
trueno_20v
Postby Lloyd » Thu Dec 01, 2005 5:53 pm
I'd be rebuilding it with low comp pistons before anything. Doubt your injectors will take much boost either, if the ECU does. I've got a spare 20V turbo manifold with a T3 hanging off it at them moment, turbo not for sale but the manifold is. Double layer of heatwrap on the entire thing too, probably was made by actiondan too even :P
http://i23.photobucket.com/albums/b387/ ... wnload.jpg
Postby EVL20V » Thu Dec 01, 2005 5:56 pm
how much for the manifold lyold? im very keen :D
EVL20V
Postby trueno_20v » Thu Dec 01, 2005 5:58 pm
Yup will do injectors to, 3sgte ones? i think. How much for that manifold? Stainless? cheers
trueno_20v
Postby Mr Revhead » Thu Dec 01, 2005 6:17 pm
yes, covered many many times.....
i wouldnt want to run ANY boost at all on the stock ecu.
first theres the AFM to think of... and then theres the fact that on NZ fuel they are on the limit anyway... 6psi wont be very nice....
Postby trueno_20v » Thu Dec 01, 2005 6:27 pm
Soo what sort of money to get after market ecu + installation approx?
trueno_20v
Postby Mr Revhead » Thu Dec 01, 2005 6:42 pm
best to ring around ppl in your area,
and depend also on what system you go for.
personally id go for a link, but microtech are an option. and if your good with sparky shit theres megasquirt
Postby Lloyd » Thu Dec 01, 2005 6:47 pm
Wanting $500. Its a pretty nicely made manifold and has at least $100 worth of heat wrap stuff on it :P
Postby trueno_20v » Thu Dec 01, 2005 9:58 pm
Ok so say i got a link or something what do you think would be a safe boost with standard internals etc, also what sorta power would you think it would make?
trueno_20v
Postby Dell'Orto » Thu Dec 01, 2005 10:27 pm
18psi, and it'll easy make 220kw
people who dont search deserve false hope and broken pistons
Postby FYADUP » Thu Dec 01, 2005 11:25 pm
yer id get low comp ZE pistons first before anything, then start from there, but def get an ecu, like link etc. ohterwise with high comp pistons even with tune, dodgy and wouldnt be reliable
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby barryogen » Fri Dec 02, 2005 10:08 am
Mmm, Boost wrote:people who dont search deserve false hope and broken pistons
although I agree with you, its a bit mean.
barryogen
2ZZ Guru in training
Postby 10k 20v » Sat Dec 03, 2005 1:51 pm
no it's not
10k 20v
Postby barryogen » Mon Dec 05, 2005 8:13 am
no it's not
False hope yes, broken pistons is just going to look like the adivce he got from toyspeed is wrong, and that doesn't really help us or them.
barryogen
Postby Drifter4ag » Mon Dec 05, 2005 1:30 pm
get 8.0:1 ZE pistons
new rings
new bearings
manifold
intercooler
link
turbo
a blow off valve
and you will be fine for some good numbers
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Mr Revhead » Mon Dec 05, 2005 1:37 pm
if going in a fwd road car id go for 8.9 for better drivebility.
a high power peaky on/off boost fwd is a bit of a handfull.
Postby Ako » Mon Dec 05, 2005 1:55 pm
Dont forget your fuelling either.
Ako
Postby crnkin » Thu Dec 08, 2005 11:18 am
Drifter4ag wrote:get 8.0:1 ZE pistons
new rings
new bearings
manifold
intercooler
link
turbo
a blow off valve
matt recomendign low comp :O what is the world comming too!
run 8.9:1 pistons, with a good af ratio, like just under 12 all the way, and youll be mint, Search club 4ag too, theyre real good, theres a guy running 650+ hp in a 4age with 8.7:1 comp ratio, only prob is the bores keep splitting...... bugger
deaf_homo "currrently yes"
crnkin
