20v gearboxes - lsd or not to lsd
Postby Lanius » Fri Dec 02, 2005 4:00 pm
Done a bit of searching, can someone confirm for me please ...
C160 = 6 speed LSD gearbox (20v)
C56 = 5 speed LSD gearbox (20v)
correct?
If changing from the non-lsd 5 speed box to an lsd-equipped 5 speed (or 6 speed) box, what else requires changing other than the box itself? I assume driveshafts etc are all the same? (fingers crossed)
Lanius
Postby IH8TEC » Fri Dec 02, 2005 4:06 pm
quick search been covered recently
Postby Silent Knight » Fri Dec 02, 2005 4:11 pm
Silent Knight
Postby Lanius » Fri Dec 02, 2005 4:23 pm
Lanius wrote:Done a bit of searching ...
IH8TEC wrote:quick search been covered recently
Can you give me a link please? I've done the search and can't find what I'm looking for.
Cheers, thats one of my questions answered ;)
Lanius
Postby IH8TEC » Fri Dec 02, 2005 4:26 pm
Postby redline racer » Fri Dec 02, 2005 4:37 pm
yep c56 is 5speed lsd 8)
redline racer
Postby Lanius » Fri Dec 02, 2005 4:38 pm
IH8TEC wrote:http://forums.toyspeed.org.nz/viewtopic.php?t=38838&highlight=c160
Awesome, just what I needed, thx :)
Now, just need that confirmation on the gearbox models ...
Lanius
Postby Lanius » Fri Dec 02, 2005 4:39 pm
redline racer wrote:yep c56 is 5speed lsd 8)
Great, thx for the help guys!
Lanius
Postby AceSniper » Fri Dec 02, 2005 4:55 pm
no c56 isnt LSD!!!!
only c56 from BZ-V and the odd other ones have LSD but 90% are open diff
AceSniper
Postby Lanius » Fri Dec 02, 2005 5:02 pm
AceSniper wrote:no c56 isnt LSD!!!!
So theres different models of C56 now? :(
Do you know how to distinguish between them? I really need to make sure I'm asking for the right parts ...
Lanius
Postby AceSniper » Fri Dec 02, 2005 5:14 pm
get a c56 out of a BZ-V, or if ur checking a g-box look into the axle hole... if u can see right though (not a metal pin half way) its LSD... or u can also do the old turn the shafts thing.....
you will have to hunt hard to find a lsd one Id think.... an hope the seller dosnt know its LSD or the value of it....
AceSniper
Postby Mr Revhead » Fri Dec 02, 2005 7:15 pm
lsd trans code ends in "C"
open ends in "A"
Postby Lanius » Sat Dec 03, 2005 3:09 am
Mr Revhead to the rescue :D
So I want a C56c for a 5 speed lsd gearbox?
Thank you kindly good sir :)
Lanius
Postby Mr Revhead » Sat Dec 03, 2005 12:07 pm
yeah theres a coupla other numbers in there but itll end in a c or a. and you those numbers are only on the build plate
Postby Grrrrrrr! » Sun Dec 04, 2005 11:10 am
Make sure you get a box from a similar motor, eg, the C160 off a 6 spd celica will not bolt up to a 4age im guessing, and i wouldn't expect a c56 or c52 out of a starlet to bolt up to a 4age either...
Grrrrrrr!
Postby redline racer » Sun Dec 04, 2005 6:16 pm
sorry for that miss-information i have a bzv which is c56 but as stated earlier dosnt always mean it is. :lol:
redline racer
Postby bad20v » Wed Dec 07, 2005 2:20 pm
AceSniper wrote:get a c56 out of a BZ-V, or if ur checking a g-box look into the axle hole... if u can see right though (not a metal pin half way) its LSD... or u can also do the old turn the shafts thing.....
Ummm.... I have a C160 out of a BZR sitting in front of me and it has a metal pin through the axle hole and it is LSD. so..... :?
Thank-You.
bad20v
