aw11 battery relocation
Postby lil » Sun Dec 04, 2005 7:11 am
Does anyone know what I need to do to relocate my battery to the front?
I can fabricate mounts etc but was wondering specifics on wiring.
lil
Re: aw11 battery relocation
Postby Ae92typeX » Sun Dec 04, 2005 9:44 am
Although not spacific to the aw, these links from a while ago deal with all you need to know except the spacific route to take your cable. For that I would just follow the main loom from the back, through the passenger side and out the front near the relay box.
Ae92typeX
Postby Mr Revhead » Sun Dec 04, 2005 12:36 pm
actually the best route on the aw11 is down the central tunnel. i just pulled off the plastic trays underneath and ran it there, zip tied in place paying special attention to any sharp bits or where it could rub, anywhere i didnt like got covered in foam rubber. as mines had the aircon ripped out i used one of the holes for the pipes to feed into the frunk, just so happens the rubber grommet there was just the right size :D
Postby Malcolm » Sun Dec 04, 2005 12:39 pm
there's a bit of info about how I mounted mine here
http://www.fasterthanjesus.net/sw11/D20.html
the wiring side of things is pretty straightforward, just earth the negative terminal, and run a power cable from battery to the starter motor, and connect any of the other wires that used to go onto the battery terminal to the starter motor also. Pays to put a couple of fuses in there too
Postby Mr Revhead » Sun Dec 04, 2005 12:44 pm
yeah i used the same point as the earth on the left inner guard.
starter motor? hehe my bastardised loom is quite different from that :lol:
